Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-31-2008, 10:31 AM
dakumanchik dakumanchik is offline
97 Firebird cuts out when engine is hot
97 Firebird runs great until temp gauge reads greater than 200 engine will miss a couple of times finally it will stall Cannot restart it Pull spug wire first coil pack No spark after cools starts v6? Ignition module checked GOOD but was checked when it was cold. No codes. New Coils/wires/plugs/ECM. Could BCM cause this problem... Security light is always on.... May have one than 1 problem... Someone said the ECM will shut down the ignition if the temp is too hot.. is that true.
Old 03-31-2008, 04:20 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 97 Firebird cuts out when engine is hot
No, it will illuminate the "Check Gauges" as a polite means of telling the Driver to wake up.
Sounds like a classic ICM failure. :scents:
Old 03-31-2008, 04:32 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
u replaced the coil pack?.....ive seen heater coils be the cause of ur symptoms.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 03-31-2008, 04:39 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
just for fun, use a voltmeter to check your injector resistance.
i would tend to lean towards something on the engine itself failing with heat. failing at 200 wouldnt really indicate a safty shut off, even if such a thing existed. the engines normally operate at around 220. so shutting off at 200 wouldnt be a safty thing. however, electronic components are effected by temperature, and when electronics get hot they expand, which can cause a circuit failure. which on a sensor, or an injector, or a coil, leads to failed operation.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-02-2008, 08:09 AM
2 out 3 coil packs have been replaced. I had the ignition mudule checked but I need to have it checked when it is hot ... it checked Good cold ...
Old 04-02-2008, 10:31 AM
wrightz28's Avatar
You are 150% correct on that notion.
