Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 04-21-2011, 03:31 AM
JAYJAY1974 JAYJAY1974 is offline
Clio 03 1.2 16v Heater problem
Hi guys,
I have th eabove,for the last couple of weeks my heater hasn't worked at all.
No hot air and no cold or air con.
I checked all fuses yesterday,no problem there,turned the car on this moring and i got a blast of cold air,the air conn worked!
Then stopped again!
All i get now when i switch it on is noises like its trying to work.
I then decided to try to get to the heater unit,which needs to be done under the wipers.
I have removed the nuts holding the wipers on,but they will not budge so i can get underneath them,any ideas?
Pretty sure i can fix this myself without having to go to a garage and pay silly money.
People i have talked to think it may be an electrical fault as my stereo won't work either.it wont play any cd's!
Even if it is electrical,i still need to get to the unit to check,but the bloody wipers wont come off,is there a diagram available?
Old 01-20-2012, 10:08 AM
Autosparkz Autosparkz is offline
Re: Clio 03 1.2 16v Heater problem
Originally Posted by JAYJAY1974 View Post
Hi guys,
Then stopped again!
power motor direct and if it works ok then maybe heater resistor needs to be replaced
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
51 reg Clio 1.2 16V starting problems (yes another one!) RK1.01 Clio/Clio II/Clio III 2 06-21-2006 02:01 PM
my car doesnt start, renault clio 1.2 16v dynamique, 51plater mohsan55 Clio/Clio II/Clio III 1 06-18-2006 12:56 AM
Renault clio 1.2 16v dynamique- where is the brake fluid thing located mohsan55 Clio/Clio II/Clio III 1 06-18-2006 12:53 AM
Haynes Manual for clio 1.2 16V Dynamique Mod. 9/2002 makiskan Clio/Clio II/Clio III 1 05-04-2006 02:48 AM
