Old 04-19-2011, 08:24 PM
FishFind FishFind is offline
One Hot Shot
arching from everywhere
99 s10 long story short, Had to change my wires and plugs, cap and button rotor. I am getting a random misfire. Changed my wires 2 times plugs 2 times and rotor and cap 2 times and also the coil. STILL RANDOM MISFIRE! Brand is autolite plugs, went back to OEM wires rotor and cap. When it got dark out I took a mist of water and I see blue from the side of the coil, and from the wires in random areas. Had my ICM tested that is fine, tested the mass flow that is fine. Also did a compression test all good. Why are the wires arching after checking spark gap and trying many sets of wires and random parts? Can the coil make the wires arch? Is it sending too much power through the wires?
NOTE: the second coil made it run good for a day or two, then bad again.
Old 04-19-2011, 10:07 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: arching from everywhere
Wow, There are 5 components to the secondary ignition system, Coil, Cap, Rotor, Wires, and Plugs. The P0300 code is Random misfire, is that what you are getting? It comes from one (or more) of the 5 components. My experience says it is usually the cap, but not always.
O.K. you said you went back to OEM. I assume that is BRAND NEW AC-Delco all the way around. Everything, Correct? Especially the CAP and Rotor or did you put the old ones back on? You did double check to make sure none of the wires got mixed up, and the firing order is good, right?
Your coil should not be arcing. It is bad, if it is new, you might take it back and get a new one.
Try putting a dab of di-electric grease ON EACH LUG on the INSIDE of the Distributor cap, and also on each wire on the outside of the cap.
Also, there are two other possibilities that come to my mind. Excessive distributor shaft play and possibly a loose timing chain. Before you spend another dime, check these two things.
Take the distributor cap and rotor off and see if you can wiggle the shaft, you should not have more than a few thousandths of side to side movement. I had one with a 1/2 inch of wiggle.
To check for a sloppy timing chain, put a socket on the big nut in the harmonic balancer and rotate the engine slowly by hand in the right direction with the distributor cap off and watch the Distributor rotor move. When you have all of the slop out, reverse the ratchet and rotate the engine by hand in the opposite direction SLOWLY. The amount you have moved the balancer in the opposite direction before the rotor starts to move tells you how much slop is in the timing chain. If it seems like you have moved the balancer quite a little bit before the rotor moves the opposite direction, the timing chain may be part of your problem.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
The Following User Says Thank You to Rick Norwood For This Useful Post:
FishFind (04-23-2011)
Old 04-20-2011, 04:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Start with pitching the autolite plugs in trash can and replace with the Proper AC delco plugs the ac delco book calls for.
Many things can cause misfire.
Low fuel pressure or Maf sensor plugs or any secandary ign parts
AND or Camshaft retard setting off.
Camshaft retard of can cause over/high spark and burn out secandary ign parts.
Casmshaft retard can only be checked or set on a engine capable scanner OBD11 or code readers will not do that.
How many misfires per cylinder or can you feel engine miss and ramdom or miss on certain cylinders?
That info ALSO can be found in a engine CAPABLE SCANNER.
MT
Old 04-20-2011, 08:23 AM
One Hot Shot
MT-2500 I don't hear or feel any miss at idle, If I am smashing the gas to the floor it seems fine also and takes off fast. but normal driving at mid range rpm's you hear and feel it bad. Sounds like a pack of fire crackers, the worst is going through a parking lot because i am at mid range rps and get alot of lookers
Old 04-20-2011, 09:21 AM
MT-2500's Avatar
AF - Advisor
Pitch the autolites a get some ac plugs in there.
Try another coil know good coil and check/set the camshaft retard setting.
Let us know how it goes.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
FishFind (04-21-2011)
Old 04-20-2011, 11:32 AM
One Hot Shot
gonna go get the plugs in a a hour or so. Ill keep ya posted
Old 04-20-2011, 12:12 PM
MT-2500's Avatar
AF - Advisor
I would pick up another coil to.the one you replace should be under warranty.
Good Luck
MT
Old 04-20-2011, 04:27 PM
One Hot Shot
Put new plugs and wires runs better"misfire less" But it still does misfire. I looked at the distributor and i can wiggle it about 1/4 inch so I am guessing that is bad. I am gonna go grab a new one and see what happens.
Old 04-20-2011, 05:22 PM
Big Tall Dumb Ass
Yes, 1/4 inch of side to side is way too much. Mine went out on a 2001 S10 Blazer and it had a 1/2 inch of slop. It actually snapped the pointer off of the rotor. If you pick up an aftermarket Distributor, like I did, don't use the new cap or rotor that comes with it, use your AC-Delco Cap and rotor.
Old 04-21-2011, 12:18 PM
One Hot Shot
ok problem, the marks came off my dis to see how to put the new one in. I did notice in the bottom of the distributor post it has a notch so it can only properly seat facing a few directions. I looked at a older thread where you can set it back to TDC and the cap should face 6 on the distributor. Mine is about a 1/4 inch past the 6 when I set it to TDC what do I do?? HERE IS THE THREAD http://www.automotiveforums.com/vbul...hlight=s10+tdc
Old 04-21-2011, 12:30 PM
MT-2500's Avatar
AF - Advisor
Make sure you are on TDC and also compression stroke TDC.
If rotor is not pointing to the 6 when dist in you will have to lift dist and reset it so the rotor is at the 6 when all of the way down.
With a little practice installing and reinstalling you shold get it set.
In some cases withn a rebuilt or another replacement dist or when replaceing dist gear the dist gear may have to be turned 190 degrees to get it lined up good.
So if it does lines up real close but not on the money turn the gear 190 degrees.
If the 6 is worn off use the notch in picture where 6 was.
After you get it set and running you will need to check/set camshaft retard with a engine capable scanner.
MT
Old 04-21-2011, 03:23 PM
One Hot Shot
it was not on the compression stroke, when I put it on the compression stroke it works perfect. So my main problem was that worm drive gear on the bottom of the rotor. The gears where worn and that allowed the cap under the distributor to move about 1/4 inch. After new rotor no movement and random misfire is gone.
Old 04-21-2011, 03:39 PM
Big Tall Dumb Ass
Old 04-21-2011, 03:40 PM
Big Tall Dumb Ass
Did you buy an OEM Distributor or aftermarket?
Old 04-21-2011, 04:26 PM
4x4 blazerguy 4x4 blazerguy is offline
Smile Re: arching from everywhere
That was my first thought when I heard Autolite plugs. It is getting to the point that if you don't use OEM parts there seems to be problems. I bought a top of the line NAPA serpentine belt for my Blazer & after a month the darn thing starts squealing. This is the second one that has done this to me. OEM BABY.
blowing oil everywhere from oil filter danmug Tahoe 1 05-06-2006 12:39 PM
blowing oil everywhere from oil filter danmug Tahoe 1 04-10-2006 02:10 PM
Rattling sound from wheel arch area. 92 Prelude! gibraltar_lude Prelude 4 12-07-2004 06:47 PM
Free Energy and Power from Everywhere Janus20 Automotive News Desk 1 06-25-2003 12:56 PM
