Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-18-2011, 12:01 PM
HeWhoKillz HeWhoKillz is offline
timing chain
Ok, I was just wanting to know how a timing chain goes out? I know with timing belts, they break, dry rot, simply get old and worn out. Timing chains? Are they the same way? See I have a 95 sentra which wouldn't start at school. It cranked but not start. After a while, it did start and i drove it home. Once it was home, it wouldn't start again. It will crank but not start. I thought it was a fuel issue. Someone else said timing chain. If it was the timing chain...would it still crank? How can it? If the chain is broken, how does the camshafts get turned?
Old 04-18-2011, 01:25 PM
inafogg inafogg is offline
Re: timing chain
its very rare that a timing chain breaks.the cam/crank gears can wear down
& cause the chain to jump.i'd do a basic inspection checking for fuel/spark
a compression test would be helpful.as far as engine cranking with a broken
belt/chain yes it will, but your only moving the bottom end.camshaft/valve
will not move
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-18-2011, 07:24 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: timing chain
If the timing chain breaks, it won't ever start again until you fix it.
First of all, a timing chain slipping a tooth would only happen long after excessive wear has cause other major symptoms. Even then, if it skips a tooth, it wouldn't cause an intermittent problem. it would run poorly until it skipped the next tooth at which point it probably won't run at all.
Not the timing chain
Dragging people kicking and screaming into the enlightenment.
Old 04-18-2011, 09:18 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: timing chain
Not that it matters, but does your Sentra really have a chain rather than a belt?
As pointed out, your symptoms are not consistent with a timing chain/belt issue. They could however be due to a failing fuel pump, restricted fuel line (when was the last time the fuel filter was changed?), or possibly a bad Crankshaft Position Sensor (CKP) or Camshaft Position Sensor (CMP). I'm not sure if Nissan requires a valid CMP signal to allow the engine to start, but most likely it atleast requires a good CKP signal. Start with the easy stuff like squirting some throttle body cleaner in to the throttle body when it won't start and see if that will get it to sputter like it wants to start or maybe even get it to start. If so, the issue would appear to be a fuel issue. Of course if you have a fuel pressure gauge you could just use that. If that has no change, then check for spark using a spark tester.
-Rod
Old 04-18-2011, 10:58 PM
Re: timing chain
Rod, they did switch to a chain in the later years,just before the sentra was dropped for the altima.just not sure what year the altima came out.i thought it was 95-96
Live For Today
Yesterday is gone,
Old 04-18-2011, 11:08 PM
Re: timing chain
who are you addressing this to??
and who said it was a bad timing chain??
the guy asked if the engine would crank w/broken chain
Live For Today
Yesterday is gone,
Old 04-19-2011, 10:43 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: timing chain
Maybe an ignition issue, when was your last complete tune-up?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 04-19-2011, 11:56 AM
Re: timing chain
My old 93 sentra with the same engine was a chain so assumed this one was to. The spark plugs and wires were changed about a month ago along with oil in about november or december. I was thinking the fuel pump myself since everything seemed to move. I know its a silly idea but could I like put a zip locker baggie over the opened oil cap (to avoid escaping oil)and start it and see if the cams are turning? To test for the fuel pump can I like pull one of the fuel lines from the firewall and see if fuel comes out when it tries to start? Or what other ways can i test the fuel pump? The car has 3/4 tank. I couldn't tell you the last time the fuel filter was changed. Might check that as well.
Old 04-19-2011, 01:00 PM
shorod's Avatar
SHO No Mo
Re: timing chain
If the pump is working you'll get a lot of fuel all over the engine bay that way. I'd suggest one of the two suggestions I made in post #4 above.
-Rod
Old 04-19-2011, 01:45 PM
Re: timing chain
And if its not working then I won't get any gas out of the hose then. Do they sell spark testers at autozone and stuff? I don't own much of this fancy equipment.
Old 04-19-2011, 02:19 PM
Re: timing chain
you can get a spark tester for $5, spraying carb cleaner in the trottle body
is an easy way to see if your getting fuel.if it tries to start then you no
Live For Today
Yesterday is gone,
Old 04-19-2011, 09:08 PM
vgames33 vgames33 is offline
Re: timing chain
All GA16DE (and the SR20 as far as I know) engines have chains. If your chain broke, as stated, you would have no start and likely a very fast cranking with little to no compression.
The GA16 should have an optical cam sensor in the distributor housing and I have heard of the distributor bearings failing causing some weird issues.
Spark testers are widely available at any tool store. Fuel pressure kits are available as loaners from any parts store. As stated, some carb cleaner or starting fluid can rule out a fuel issue pretty quickly. Just be careful, as I have had some engines backfire and ignite residue in the intake track
There is a no start/hard start TSB for all Nissan models through 96 stating that you may have to pull out the pump fuse or floor the throttle to get the engine to start. It then says to check base idle and ignition timing.
Old 04-20-2011, 01:44 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: timing chain
Timing chains can wear and become loose enough to throw off the cam versus crank timing, but it would have to be severe wear to prevent starting...jumping a tooth ot two.
I'd look more at a weak ignition coil, a faulty engine coolant temp sensor, or possibly a stuck IAC or EGR valve if it idles poorly when running.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 06-05-2011, 08:32 PM
Re: timing chain
Ok so we change the fuel filter and there is gas coming out of the hose when you start the car. Still only spins the engine. It doesn't really sound like its firing. Could it maybe be the distributor? I thought maybe the spark plugs and then I thought how many spark plugs would have to die (or spark plug wires) to make the car not start at all? Not even try???
Old 06-06-2011, 08:37 AM
jdmccright's Avatar
The RustBuster
Re: timing chain
An engine might run on two firing cylinders, but no start means it's not spark plugs...it's upstream electrically. Either the ignition coil, igniter, or the distributor.
Test the coil and igniter (if equipped), check all engine grounds, and in the distributor check for excessive play, broken cap contacts, and melted components.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
1998 Ranger 3.0L V6 - Timing belt or chain? ecamc Ranger | Courier 2 08-05-2010 09:50 PM
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 10:18 AM
What extra parts needed to replace timing chain, 97 Grand Am GT 3.1? Which chain? skseattle Grand AM 1 05-29-2010 03:40 PM
timing marks/balancer Top Dead Center thehustler211 Problem Diagnosis 1 03-28-2009 11:31 PM
Balancer chain and timing chain timing DunksAuto 9-3 0 02-11-2008 02:05 PM
