Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-14-2011, 02:20 PM
emsp80 emsp80 is offline
Send a message via AIM to emsp80
2000 Impala Running Rough
Started my 2000 Impala this morning and was running very rough and the check engine light was flashing. The same thing happened again when I started it again in the afternoon. Thinking in might be the cat. Any other suggestions would be helpful...
Old 04-16-2011, 02:38 PM
j cAT j cAT is offline
Re: 2000 Impala Running Rough
get the code reader //post backthe code.
Old 03-28-2012, 07:08 AM
DJRedZ242 DJRedZ242 is offline
I know this post is old, but the exact same happened to my car last night. The check engine light is flashing and the car is running a bit rough. I had a similar problem a few months ago only to find that one of the coil packs needed to change (but I don't remember the 'check engine' light flashing)... could it be that the other pack now has to change?
Old 03-28-2012, 08:04 AM
maxwedge maxwedge is offline
A990 racer
A scan will show which cylinders are misfiring.
Old 03-29-2012, 07:08 AM
luvmy02impala luvmy02impala is offline
I had that issue with my 2002 Impala. 2 of the 6 spark plugs failed. I changed the plugs and all was well. Well, they did have 151k miles on them. LoL.
If you don't have access to a code scanner, I believe Auto Zone will do it for free.
-Tom
06 Impala LT
12 Cruze Eco
02 Impala (sadly - it burned up)
90 Dodge Dakota (donated)
Old 04-01-2012, 08:45 PM
la1's Avatar
la1 la1 is offline
if u think it is the cat, take the ox sensor out, if it runs better more than likely the cat / exhaust is clogged
2000 explorer runs rough benn1235 Explorer | Explorer Sport Trac 5 02-17-2006 07:44 PM
2000 sportage running rough gr8pmpkn Sportage 4 01-03-2006 02:11 PM
2000 wrangler running rough/lunge Sfrid073 Wrangler 1 07-20-2005 11:05 AM
2000 TJ Running rough Sfrid073 Wrangler 0 07-13-2005 12:55 PM
2000 Xterra Running Rough LanPhantom Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 02-02-2005 10:55 AM
