Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 01-01-2006, 08:54 PM
gr8pmpkn gr8pmpkn is offline
Question 2000 sportage running rough
I have been having issues with my 2000 sportage for almost a year now. The check engine light is on and it idles rough. When I accelerate, the engine light flashes on and off and I have very little power. When I get to highway speed, it seems to run ok, but when I shift up or down, it sputters. There is also a burning smell and the occasional pop (backfire I guess). I went to autozone to have the codes checked. The computer is displaying 2 (P0303 Misfire detected - Cyls. 1-4. & P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor). So far I have cleaned the IAC, changed out the sparkplugs, inspected the wires & mass air flow sensor (both look good), and replaced the fuel filter with no success. If anyone has any ideas of what I can try next I'd appreciate it. A dealership wants to charge me an arm and a leg just to change out everything and hope for the best.
Old 01-02-2006, 08:59 AM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Re: 2000 sportage running rough
Look closer at the wires and make sure that there is no carbon tracking on them. You may have a small spot of white on the wire were it is arching thru. At any rate I would change them anyways, they are inexpensive.
If you keep running the vehicle with a misfire you are going to damage the converters.
Thats where I would start.
You may also have a sticking injector but it is unlikely because it usually comes and goes.
Old 01-02-2006, 10:39 AM
Re: Re: 2000 sportage running rough
Thank you for the info. I will change out the wires and let you know if that helps.
Old 01-03-2006, 01:20 PM
Talking Re: Re: 2000 sportage running rough
Thank you MTC! You were right, there was a white mark on one of the wires. I installed the new wires and my sportage now runs great. The check engine light is out, I have power back, and no more backfire. Pep boys is making a killing for those wires though. 52$ for 2 wires. Even the guy at the counter had to do a double take when he was ringing me up. Anyway, thank you again for helping me out. You saved me a #$#* ton of money!
Old 01-03-2006, 02:11 PM
Re: Re: Re: 2000 sportage running rough
Ouch thats a little pricey.
We sell them at 15 bucks a piece.
Never thought the dealer would be less than the aftermarket.
At least its running right for you. Anytime you need any help, let me know.
