Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-07-2006, 12:16 PM
benn1235 benn1235 is offline
2000 explorer runs rough
i have a 2000 with 70000 miles and all the sudden it started running rough and check engine light came on help
Old 01-07-2006, 04:23 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2000 explorer runs rough
Have the codes read. Some chain parts stores will rad them for free. They will probably be somewhere between P0300--P0310. If any of these codes come up, you have an engine misfire and will need to have a tune up.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-07-2006, 06:02 PM
Re: Re: 2000 explorer runs rough
i tried that and when the plug the code reader in it would not do anything we tried it on another explorer and it worked fine so no i have another prob
Old 01-07-2006, 06:33 PM
way2old's Avatar
TOKEN HILLBILLY
Check all your fuses under the dash. Check fuse # 17. It should be a 25 amp that also feeds the cigar lighter. That is the fuse that powers the OBDII connector.
Old 01-08-2006, 01:07 PM
thank you for your help !!!! Ben
Old 02-17-2006, 07:44 PM
JustGeorge JustGeorge is offline
I have the same problem with a 2000 explorer with 90,000 miles. It just started last weekend. Since I use my power plugs, I know that what was suggested as a fix isn't the problem. Was it yours? If not, have you found a fix?
