Old 04-12-2011, 11:42 PM
ericcfx1984 ericcfx1984 is offline
what would cause the cylinder 5 to look like it got hot???
ok so I finally got around to talking off the heads...
turns out that they are warped... mostly on the rear head
but basically the exhaust valve on cylinder 5 is CRAZY clean, it looks like it was steam cleaned or something... (the left side cylinder, on the rear bank)
the other thing is the bore on that cylinder looks like it got REALLY hot... maybe black or purple...
If I recall correctly that cylinder is last on the fuel rail...
could this be caused by overheating... or could it BE THE CAUSE of the overheating?
any ideas?
Old 04-13-2011, 09:14 AM
skeeter123 skeeter123 is offline
Re: what would cause the cylinder 5 to look like it got hot???
I've heard that coolant leaking into the cylinder makes a great cleaner....
Old 04-14-2011, 01:17 PM
any one else?
Old 04-14-2011, 03:43 PM
inafogg inafogg is offline
any ideas?
yes if the cylinder is burning coolant(bad h/gasket)you will see it as being clean
resurface/repair the head,making sure guides & seals are done
would'nt be a bad idea to do the other head
Good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-14-2011, 03:53 PM
yeah I was planning on doing both
Old 04-16-2011, 09:32 AM
ok, so I am on the right target?
Old 04-24-2011, 03:56 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
So you steam cleaned your cylinder head by running it with the blown head gasket and water you used to as coolant leaking in....
Get the heads worked over, but dont spend a lot, 3400 heads are everywhere. Then check fuel pressure once you get it running.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
The Following User Says Thank You to tblake For This Useful Post:
ericcfx1984 (04-24-2011)
Old 04-24-2011, 03:57 PM
tblake's Avatar
In God We Trust
I wonder why that coolant/combustion gas tester didn't work.....
Old 04-24-2011, 05:07 PM
well the gas tester looks for combustion gas in the coolant... but it was going coolant into the combustion camber... not the other way around
Old 05-16-2011, 11:06 AM
tblake's Avatar
In God We Trust
Yes but the combustion pressure in the chambor is much higher than the 15psi in the cooling system.
Old 05-16-2011, 06:58 PM
yes but sometimes they can blow the gasket and the break acts like a check valve
what would be the cause of toasted rod bearings? silvawolfe Trooper | SLX | Bighorn | Wizard 3 01-03-2006 06:52 PM
Just if ne-one wanted to know what the Cedric looks like.... NB8CT Cedric | M45 | J30 | Gloria 7 07-13-2005 12:08 PM
what would cause an backfire...threw the intake? BlazinUP S-10 11 03-22-2005 04:39 PM
whats the dash look like w/ no navi? bobo_80 Nissan 350Z/370Z | Infiniti G35/G37 Coupe 2 09-19-2002 10:08 AM
