Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-11-2011, 11:16 PM
floridaford2011 floridaford2011 is offline
1996 Contour 2.5L LX "No Radiator fans"
Could someone please help with an issue where the radiator fans won't cycle on and off. I've changed the resistor on the fan shroud, coolant temp. sensor, temp. sending unit, and the ECU. If you allow the engine to get to 220+degrees the fans won't kick on. Yet if you turn the engine off and turn it to acc. (without starting), the fans will blow. Yet as soon as you start the engine, the fans cut off. The fans will then blow whenever the ignition is in acc position (without starting), they won't stop doing this, until you disconnect the battery and allow the ECU to reset. After resetting, the fans will no longer blow in the acc. position until the engine gets hot again. If anyone can steer me in the right direction for a fix to this problem, it would be greatly appreciated. Also, I don't have any codes being thrown.
98 contour 2.5l dohc misfire/rough idle mre4ever Contour 11 02-12-2015 07:36 PM
Problems with my 1999 Mazda Millenia V6 2.5L IcyBob Millenia/Xedos 9 0 01-04-2010 06:04 PM
99 Contour 2.5L Question!!! erife2003 Contour 2 12-30-2006 10:28 AM
lookin for a supercharger for a 1995 contour 2.5L V6 contourjosh627 Contour 2 08-10-2005 07:37 PM
'95 Contour 2.5L, Starter Replacement ggcatt Contour 0 01-11-2005 10:23 AM
