Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-30-2006, 12:58 AM
erife2003 erife2003 is offline
99 Contour 2.5L Question!!!
I just bought this car from my brother a few days back and it runs perfect but the only problem I notice is that when you put the pedal to the floor at about 6000rpm the battery light comes on and power dims. This is only when u gun it. Any ideas. I was told maybe the belt was slipping at higher rpm maybe needs replacing. Well if you know what this is let me know.
Old 12-30-2006, 10:03 AM
butch h butch h is offline
Re: 99 Contour 2.5L Question!!!
You are probably at the governed rev. limit.
Old 12-30-2006, 10:28 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
rev limit is at 6750 rpms. This wouldnt cause the battery light to flicker.
You may want to replace the megafuse and go from there. Sometimes it can be partially blown and the battery light can flicker. Its only about a $7 fix.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
