Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-16-2008, 06:11 PM
mre4ever mre4ever is offline
98 contour 2.5l dohc misfire/rough idle
im new to this thread, however, i've pretty much read almost all of the contour threads on the problems these cars have. timing chain, vacuum leak, etc. Here's my problem/s.
I bought this car 2 1/2 weeks ago. ran good, no check engine light, nothing. then I started it up one day, and it ran the rpm's up to 2500 and back down to 300. If it doesn't die, then it goes back up and down several times until its warmed up. It still does it every day. Once it's warmed up it idles where it's supposed to, around 900 -1100 rpm somewhere in there, however it's still rough. I just replaced the plugs and wires, being that's the cheapest test. No change. Does the same thing. The only other problem, that I know of is that there's a small oil leak on the back valve cover. I check the oil everyday, and it isn't even 1/2 qt low in 2 1/2 weeks. Don't think that it's related to this problem. My guess is a coil pack??? or a maf sensor??? just looking for the best direction to go, without spending big $$$$ fixing this annoyance. Thanks in advance. O, I got the check engine light flashing, and the codes when read were, misfire on 1, and 3. car running to lean/rich, and o2 sensor upstream.
Old 02-17-2008, 06:03 AM
Davescort97 Davescort97 is offline
Escort guy
Re: 98 contour 2.5l dohc misfire/rough idle
Check the PCV valve and vacuum line going into the intake plenum. Sometimes the elbow develops a crack in it. Replace the PCV valve since it's only a couple bucks.
Old 02-17-2008, 10:47 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
V6's do not have problems with timing chains, so that eliminates that possibility. Youre probably thinking of the timing belt on the I4.
This problem however, is probably covered in the contour.org FAQs.
Engine idles high.
http://contour.org/FAQ/FAQ.php?s=probs&displayid=7
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-18-2008, 09:12 AM
Thanks guys, I will go ahead and try all that stuff tonight. I'll let you know how it works out. O and appriciate letting me know the whole timing chain thing. I am mechanically savvy, however, not good enough to do a complete rebuild. Thanks.
Old 02-19-2008, 07:26 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Yeah bud, O2 sensor should do ti. If that fails then your MAF sensor. Allthough you didin't post a bad PCV in the codes.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-19-2008, 08:28 PM
No way an 02 sensor would cause irratic idle.
I think most people think that if it throws a lean or rich code, that they think there O2 sensor is faulty, when in reality, its working perfectly and telling you exactly whats going on. If your O2 sensor is faulty, it will give a code like P0140: "Downstream Heated Oxygen Sensor circuit Faulty - Bank No. 1."
I would say, with an irratic idle, your more than likely running lean. Unmetered air is bypassing the MAF and causing your RPM's to shoot up. Could be IAC like I said. If your intake manifold gaskets are original, I would check those next. Those deteriorate pretty bad due to high engine temps and old age.
Btw, was it running lean or rich? It can't be both at the same time. Do you have the codes handy?
"The CEG Nazi"
www.contour.org
Old 02-20-2008, 09:09 AM
JoeShmoe's Avatar
Ditto, codes would really help. You're right, I was thinking about the downstream one. Does the IAC throw a code?
Basically, you are having a problem with air, thats all these units do.
Old 02-28-2008, 08:19 PM
godfrey1680 godfrey1680 is offline
sounds like the throddle positioning sensor to me. I had that problem on my ford explorer.
Old 02-29-2008, 03:14 AM
jsweeter jsweeter is offline
Sounds like what my car had about a year ago. I had a thread posted and it was the Idle Air Control valve (IAC) Try this before anything else. Does it make a humm noise at all?
Old 05-04-2008, 11:39 AM
pjw73nh pjw73nh is offline
Had a similar issue a month ago. Turned out to be intake manifold gasket(s). Upper was leaking, but did the lower one while i was in there.
Old 05-04-2008, 06:22 PM
Like I said in my earlier post. Intake manifold gaskets.
"The CEG Nazi"
www.contour.org
Old 02-12-2015, 08:36 PM
FUKENEH FUKENEH is offline
Had the same issue. First i replaced the upper intake manifold. This did not fix the problem.
The problem was the gaskets around the spark plugs on the valve covers. Got oil on the spark plugs and caused a misfire.
