Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-11-2011, 07:06 PM
TimLora TimLora is offline
1995 cutlass shifting problem
Howdy, My 95 cutlass supreme has a new problem. It seems to shift too soon causing a jerking and bogging down. It also sputters when I'm on the interstate and step down on the accelerator. 25% of the time it simply runs great with no problems at all. It started doing this right after I had the rear break lines replaced. Could they have knocked something loose or something. The trans fluid looks and smells new. Any help is appreciated. Confession, I'm no mechanic.
Old 04-11-2011, 07:12 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 cutlass shifting problem
This requires some diagnostics, low fuel pressure, clogged fuel filter, bad maf, many things can cause what you describe, no quick answer for this. Usually what was done on the brakes shouldn't affect performance unless a line was crushed or kinked during the process.
The Following User Says Thank You to maxwedge For This Useful Post:
TimLora (07-18-2011)
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
88 cutlass shifting problems? |WYG|SS Cutlass Series 2 02-10-2010 02:38 PM
97 Cutlass shifting problem doctorptwo Cutlass Series 1 07-21-2008 06:13 AM
96 Cutlass shift problem Elishaman Cutlass Series 1 04-10-2005 07:11 PM
1995 Cutlass Alternator Problems 3.4 Engine brockhaus ronald Cutlass Series 3 05-19-2004 05:22 AM
