Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2011, 10:06 PM
jonv392 jonv392 is offline
95 eclipse auto transmission problems
95 eclipse auto 4 cylinder. When car is first started it works. When the transmission gets hot it slips out of gear and wont go. If I shut it off and restart it works for about a min then slips out again. Any help would be greatly appreciated
Old 04-16-2011, 07:10 PM
Re: 95 eclipse auto transmission problems
OK I have reverse all the time. Thetranny slips outgoing into second pulled the pan replaced filter no metal or anything it was very clean could it be the speed sensor.
Old 04-18-2011, 04:40 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Welcome to AF.
If the tranny is slipping out of gear slipping in gear it probably has some internal damage and needs to be rebuilt. Im not to familier with the auto trannys but slipping is never a good sign.
If you put the car in L or 1st and drive slow is there any issues? What about when you shift it to 2nd manually.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-18-2011, 04:56 PM
Ok I think I gave the wrong impression with the word slip. When I first start the car and its cold the tranny works fine after I get to driving temp I take off tranny is pulling when rmps raise to shift point it goes out like I'm in nuetral. I've tried shifting manually but nothing oonly thing that works is reverse. If I shut the car off and restart it will takeoff again but goes out when it should shift. I've replace the input and output speed sensor and changeded the fluid and filter and it still does the same thing. When I pulled the pan from the tranny it was very clean barely any. Metal shaveings on the magnet and the fluid was not burnt
Old 04-19-2011, 10:20 AM
Holset powered 420a
Could be TCU related from the sound of it. Since the problem goes away when you cycle the key. I have never been a fan of throwing parts at a car to try and solve the problem but in this case it would be cheaper than tearing into the tranny. If that doesn't fix it then it might be an internal issue.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-19-2011, 10:43 AM
Thanks for the help I've had a few people tell me that so I think ill give it a try. Others have told me maybe the speed sensor
Old 04-24-2011, 02:40 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I also suspect the TCU as possibly being the problem in this case. You could probably pick up a used one for about 50-100 dollar range.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-07-2011, 11:44 AM
Ok so I replaced the tcu and its still doing the same thing. I have a steep driveway and I can pull it up and down all day long and it works but as soon as I get out on the road and pick up speed around 15 and 20 mph it goes out like its in nuetral.I turn the key off and right back on and I can slowly get it back to my house. Now fluid has been changed input output speed sensor and tcu could there be something else going wrong. Thanks for any help
Old 05-07-2011, 11:50 AM
I forgot to mention I am not getting a check engine light
Old 05-09-2011, 09:17 AM
Hmm... I would have thought that would have fixed it. About how many miles are on the car? I wonder if it's possibly the torque converter which will be a bit more work to replace if that's the case...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-09-2011, 10:39 AM
The car has 132000 miles on it. Reverse always works. Even when my forward gears go out reverse works perfectly
98 Sport Auto Transmission Overheats gromittoo 1st Gen 95-99 1 08-06-2010 06:16 AM
1995 Eclipse fwd auto transmission problems jimmy751000 Eclipse Problem Diagnosis 9 10-24-2005 07:54 AM
Eclipse Auto Tranny Problems **Need Help Please** 19eclipse97 Off-Topic 4 09-09-2004 05:44 PM
Auto Transmission Problems lordrashmi Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 05-04-2003 07:37 PM
'85 325 e auto transmission problem bigreddog 3 Series 2 10-11-2002 08:00 AM
