Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-09-2011, 08:56 PM
odini4i odini4i is offline
1988 Thunderbird 302 HO
I am looking at a 1988 Thunderbird with the 302 HO AND turbo. It has five speed manual in it as well. Can anyone tell me anything about this vehicle? Is there anything to watch out for in particular besides the occasional ticket? I'd also like to find some place to get the HP rating for it as well. This is not a mod....I don't think. I believe it is all stock. Sorry if this has been up before. I couldn't find this info.
Old 04-09-2011, 09:17 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1988 Thunderbird 302 HO
Welcome to the forum!
If it's a 302 with a turbo, it's not stock and it's probably been run pretty hard. If it's a "Turbo Coupe" then it's a 4 cylinder.
Since you're asking for information on a specific model, I've moved this to the Thunderbird forum where they will likely be able to give you more specifics on what to look for.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
odini4i (04-09-2011)
Old 04-09-2011, 09:21 PM
Thanks alot. All I can really tell anyone about the car is that it does in fact look like a Turbo Coupe. It has the boost gauge in it, and it says 302 HO on the sides of the car in line with the pinstriping and it's the same color. I will continue to try to get ahold of the owner to get more info on it.
Old 04-10-2011, 11:16 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
In the late '80's, Fords performance Thunderbird was the turbo 4 cyl, with a 5 spd option.
302-powered Thunderbirds got a low-output version of the V8.
They never offered the HO version of the 302 in the Thunderbird.
However, this was a somewhat -popular conversion...... take a Turbo Coupe and swap in a Mustang HO 302 and 5 speed in place of the original turbo 4.
It's a straight bolt-in, fairly easy to do and gives you Mustang performance with T-bird room and luxury. The swap works best if you install V8-thunderbird front springs.
If the car is in good shape and works well, it would be an interesting ride.
Old 04-10-2011, 09:26 PM
The exterior of the car is fantastic.Not one spot of rust or dent on it. I think there is a small scratch on the front fender.The pinstripe line was well done also. At the front of each door, just behind the fenders, are the 302 HO letters in perfect line with the striping and the same color. I still have not had any luck in contacting the owner.
1988 Thunderbird question PLEASE help Resendiz Thunderbird 8 02-14-2006 12:08 AM
1988 thunderbird navigation system???possible?? THA88BIGBIRD Thunderbird 4 10-25-2005 01:19 PM
1988 thunderbird blacky Thunderbird 1 07-25-2004 10:39 PM
1988 Thunderbird Customizations MusicMesa Thunderbird 1 04-15-2004 06:05 PM
1988 Thunderbird for sale 5.0 L V8 Wagermart Thunderbird 0 01-13-2004 06:41 PM
