Old 04-07-2011, 04:52 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
Question No reverse light 2007
07 caravan sxt 3.3
No reverse lights
-bulbs arent burned out
-looked in fuse panel and no particular fuse is named for reverse lights but there is nothing blown i checked them all
- ive read about a backup light switch on the tranny but only on 2002 and older models i cant find info for my 2007. scratching head....
1991 Jeep Wrangler 4.0 (3rd child or 2nd wife)
1999 Chevy Suburban 1500 5.7
2005 Toyota Rav4
1994 S-10 Blazer 4.3L "W" "Dead and gone"
Old 04-07-2011, 05:23 PM
jpb53 jpb53 is offline
Re: No reverse light 2007
Here's a wiring diagram.
Old 04-07-2011, 05:36 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The backup light switch is the Transmission Range Sensor or TRS. It's located inside the transmission. There is an external connector. Try wiggling the gear shift. Lights come on?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-07-2011, 06:48 PM
Goober
i just tried the wiggling the gear lever to no avail with the wife behind van looking for signs of light. i will get on testing the grounds although the "sockets" arent really sockets.
on a side not does anyone sell that TRS sensor? didnt see it on autozone website
2005 Toyota Rav4
Old 04-07-2011, 09:41 PM
hundahunta hundahunta is offline
possible bcm.....try ground pin 37 at the pcm to bypass the trs. The fcm busses the message to the bcm. The bcm turns on the lamp...
Old 04-08-2011, 01:27 PM
Goober
i find it hard to believe a bcm could be bad with the only symptom being reverse lights.
there is 1 other thing to note the van got t-boned a month or 2 ago, (barely) just a caved in slider door on passenger side and its fixed now. is there a chance the wires run near there and are grounding out or got pinched or something? it seems that each side is ran separatly so i dont know how that would affect both. I dont know what the deal is.
I will say, to hell with new vehicles, the companies try to make them so people cant fix them without grabbing their ankles at the dealer and i refuse to do that. i will just live without them if it comes to that
2005 Toyota Rav4
Old 04-08-2011, 05:34 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
...or disconnect the TRS connector and ground contact #9. Will accomplish the same (bypass TRS) but probably an easier access. Just be damned sure you are grounding contact #9 as messing with PCM inputs can be risky. While there check the TRS connector for damaged/bent/corroded contacts.
I checked a few of my regular sites for the TRS. No luck.
There have been complaints of loosing the instruments, stalling, and other electrical ghosts caused by a chaffed wire harness in the bottom of the sliding doors. Data bus wires would short against the frame. There was even a safety recall for newer model 5th generation vans for it. Claimed it was a fire hazard. I doubt that would cause just a problem with reverse lights.
Gotta agree. Why route power through that many components for a simple reverse light circuit? A switch, some wire, and the light sockets would work just fine. I can picture the engineers sitting around a table puffin cigars laughing and saying, now they HAVE to bring them to the dealership. We gotem by the short curlies boys!
Old 04-08-2011, 06:02 PM
as cars become more electronically controlled it is harder for an individual to diagnose their own vehicles. Take the reverse light circuit for example, just imagine if this circuit was not controlled by a module (bcm, fcm, etcc.). You would need a wire from the switch to the reverse lamps, to the tcm, to the pcm and cluster. That's a lot of wires for 1 circuit, imagine how many circuits a vehicle has, it would take miles of wires for a vehicle's electronics. The engineers started to multiplex wires and bus the messages to combat this issue. I understand the frustration of the people, just imagine doing this day in and day out.
Old 04-08-2011, 06:24 PM
Goober
i see 3 to 4 things on the top of the tranny that are some sort of sensor or wire harness how would i be sure which is the trs?
2005 Toyota Rav4
Old 04-08-2011, 11:34 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
I hear ya. Me? I'd stick a switch in the gear shift mechanism, wire, lights, done. Thats all a reverse lights circuit deserves. In any case, many would gladly accept that extra 30 pounds of wire, yours truely included. Somehow the old KISS approach has gone by the wayside. Ok now back to reality.
Old 04-08-2011, 11:35 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Look for the connector that sits verticle on the right side front. All others are horizontal. Should have in the neighborhood of 10 wires.
Old 04-09-2011, 07:16 AM
Tranny wiring diagram.
Old 04-13-2011, 02:55 PM
Goober
A valuable lesson has been learned. Just because the filaments arent broken or damaged, doesnt mean the bulb Isnt dead. my last ditch effort was to change them anyway just to see and they work. Sorry to waste your time.
On a side note they have plastic base instead of screw in kind so maybe something went wrong inside there. Guess i should have done that first /facepalm
2005 Toyota Rav4
Old 04-14-2011, 03:13 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Bit by the basics bug. We've all been there. Happy to hear it was an easy fix.
rear-light warning signal and reverse lights up on brake 1993 Camry LE V6 patmanj20 Camry/Camry Hybrid/Vista 7 07-24-2008 01:01 AM
Reverse lights,alarm lights &signal indicator doesn't work Bigpauly52 7 Series 1 06-08-2005 02:34 AM
'90 Chevy 2500. No reverse lights. Where is Backup light switch? kpwall Engineering/ Technical 0 01-11-2005 07:46 PM
2000 Silverado--Reverse lights/cargo light Ruralmedic Silverado 6 12-30-2004 07:20 PM
no backup lights - reverse light switch? blhfla Golf 2 02-08-2004 01:51 PM
