Old 04-07-2011, 10:18 AM
shineofleo shineofleo is offline
Advice for painting top studio small connectors
I think many of you are familiar with Top Studio and its detail parts. For example, TD23010 and TD23011 are small connectors, quite useful. On TS home page there is some information, but I am not quite sure about the procedure so you advice is appreciated! Here we go...
* They are resin, do I need to coat the prime first?
* TS tip4 say using Mr. hobby SM01 as the base coat. After the first question, is it applied by airbrush or hand painting? I just want to be lazy since these are very small parts anyway...
* So what is your optimized procedure with these tiny parts? They are small, but really need to be treated well to have a 'metal feeling'!
Thanks!
Old 04-07-2011, 01:55 PM
racer93's Avatar
racer93 racer93 is offline
Re: Advice for painting top studio small connectors
Thanks!
I do prime, as resin can "suck" paint up and require multiple coats.
It depends on what color you need to paint them, bronze or black. If black, just a semi-gloss or flat black will do. If bronze, I usually use a gold over black and it tends to work well. I normally paint them before removing them from the sprue.
I've used them a bunch and that's what I have found successful. You can even use a toothpick or a fine wire to paint them once on the model if you're ambitious!
Old 04-08-2011, 04:06 AM
Thanks. In some tutorial they paint transparent color on the silver to create something like 'gold' (silver + clear orange on it) effect. But again, this can be good to do big parts, for small part, I think it is too complicated.
Old 04-08-2011, 07:38 AM
racer93's Avatar
Yep, the clear orange over silver trick does produce "gold". I've seen it work beautifully. However, it's easiest to put the *least* amount of paint you can on a small part to try and not cover details. It's easy to do with acrylic or enamel paints that tend to go on thick.
Daniel
Old 04-08-2011, 10:09 AM
A quick one: which one is preferred, hand painting or airbrush the clear color?
MP4/13 by TOP STUDIO!! vrossi85 Car Modeling 4 06-23-2009 06:41 AM
2008 YZR Super detail set from Top Studio allnie Car Modeling 15 03-11-2009 01:11 PM
Hobby design vs. Top Studio chain sets JimboCO Car Modeling 11 02-20-2009 10:12 PM
Top Studio Electrical connectors - Question? klutz_100 Car Modeling 9 10-24-2007 04:48 PM
How do you hold small parts for painting/spraying? Bangai-o Car Modeling 9 05-26-2004 04:46 AM
