Old 05-23-2004, 10:47 AM
Bangai-o's Avatar
Bangai-o Bangai-o is offline
How do you hold small parts for painting/spraying?
I was looking through the FAQ and noticed that there was nothing about this in there and it's part of modelling that I struggle with. I've seen that some of you pierce cocktail sticks into polystyrene and then somehow attach the parts to these cocktail sticks. Does anyone have any close-up photos they could help me with this? How do you attach the parts without covering up a bit of the part you want to paint?
Also how do you hand paint small parts?
Many thanks
Justin
Ferrari 250 GTO Progress. Porsche 911 GT3 Complete.
Old 05-23-2004, 10:50 AM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
Well, I leave every part on the trees, but when I need to take it off, I cut the tree's apart, so each individual part has a little piece of sprue attached still, this is what you can tape your cocktail stick to.
Old 05-23-2004, 11:10 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: How do you hold small parts for painting/spraying?
that is very similar to the way I do it. Sometimes it depends on the part.
-Mike
Old 05-23-2004, 04:45 PM
CADguy's Avatar
CADguy CADguy is offline
I use blue-tack, or fun tack. And attach the part to the end of a long skewer stick with that.
Matt
Old 05-24-2004, 11:00 AM
proosen's Avatar
proosen proosen is offline
I often take a long way around to solve this problem. After cleaning the parts up I glue them back on the sprue, in a place that will not be seen when attached. All parts that will have the same color on the same sprue. With this method I don't have to do any touch-up on the parts, just snap them of when they are to be used. Another method of mine is Blue-tack on old scrapped thoothbrushes or I'll use my small clips on a stick to hold whatever part needs to be hold.
Niclas
Old 05-24-2004, 11:07 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Try checking the How To sections for info also
http://www.automotiveforums.com/vbul...d.php?t=169906
D
Old 05-24-2004, 11:09 AM
doraemon doraemon is offline
I take it off of the sprue and using a sprue piece blend it with fire to fit the shape of the piece, and like it cannot be glued with the melted plastic, I use a bit of superglue, beacuse after painted, you can remove it kindly without any force but its stronge enough to hold the air of the can or the airbrush in my case.
Old 05-24-2004, 10:54 PM
Naseer23's Avatar
Naseer23 Naseer23 is offline
Send a message via MSN to Naseer23
I paint all my parts when they are on the thing they come on (dont kno if thats what they call the sprue)
Old 05-24-2004, 11:01 PM
mike@af's Avatar
Parts tree.
-Mike
Old 05-26-2004, 04:46 AM
primera man's Avatar
"P-Man"
Leave the part holding onto the tree by just one long bit if possible, or add a long tooth pick to it.
Attach this to a clothe's peg to hold it as you paint
View All My Models Here.
