Old 04-06-2011, 04:47 AM
edwing666's Avatar
edwing666 edwing666 is offline
Wanted Miniature Springs
Hi friends,
Where can I find miniature springs? I would use this type of accessories in the detailed of model motorcycles and model cars engines (1/25 to 1/6 scale models). I know how I can simulate a spring, winding a fine wire. But I want something more realistic and nothing like a real spring.
For example:
Very thanks!
Ed
"The madness deserted of the reason creates monsters, but together they create the mother of the arts." Goya
"La locura abandonada de la razón crea monstruos, pero unida a ella es la madre de las artes." Goya
Old 04-06-2011, 10:00 AM
luchoteam's Avatar
luchoteam luchoteam is offline
Re: Wanted Miniature Springs
Hi!
Im not sure, but i thing i saw some tutorial that uses the inside part of a incandscent light bulb, the idea is to break the glass, and remove the little filament wire
Maybe it helps!
Good luck!
The Following User Says Thank You to luchoteam For This Useful Post:
edwing666 (04-06-2011)
Old 04-06-2011, 11:53 AM
dedhaz's Avatar
dedhaz dedhaz is offline
Hi!
Tuner Model Manufactory (make) sell different springs
for example T2M-2015-E 1.45mm*150mm*5PCS
also they have 0.6, 0.8, 1.0, 1.1, 1.3 mm, if You want I can make more detailed photo (I have all of them).
Also You can take it from 1/12 moto details, for example
Top studio
Hobby design
http://www.scale24.ru - Hobby Design, Tuner Model Manufactory, Crazy Modeler, Top Studio, KA-Models - Moscow, Russia.
The Following User Says Thank You to dedhaz For This Useful Post:
Old 04-07-2011, 08:00 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I like to go down to the model railroad shop and get the springs they use for the automatic couplers. They are compression sings so they already look like they're under tension. And they're cheap!
Old 04-07-2011, 11:54 PM
denilsonvm's Avatar
denilsonvm denilsonvm is offline
Model Car Garage has "Throttle Return Springs"
http://modelcargarage.com/store/pc/v...5&idproduct=56
On Google you will find some pictures.
The Following User Says Thank You to denilsonvm For This Useful Post:
edwing666 (04-08-2011)
Old 04-08-2011, 12:06 AM
edwing666's Avatar
Thank you very much for the information.
Old 04-08-2011, 12:07 AM
edwing666's Avatar
Very thanks for the information.
Old 04-08-2011, 08:36 AM
rallymaster's Avatar
Hi Ed,
if size can match your needs, Tameo Kits release some 1/43 F1 damper springs and full shock absorbers including springs, but they are springs for that purpose and don't really match Moto GP exhaust springs for example without a bit of work.
items are:
PG01: springs
PG17: Shock absorbers type "C"
PG16: shock absorbers type "B"
logically (but I don't have it in hands) PG15 should be type "A" and I believe there also a "D" type under PG18 ref.
If you need I can take pics, or try to measure the springs. Feel free to ask.
Phil
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 08:25 PM
Wanted WTB: Springs for 95-99 Maxima RastaManMax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 04-16-2003 05:07 AM
Wanted! H&R springs for P11 Plat-num Suspension 7 02-24-2002 07:21 PM
Wanted! H&R Springs for P11 Plat-num Classifieds 3 02-21-2002 07:42 PM
Want Eibach springs for P11 Kenny-G Classifieds 0 12-18-2001 01:37 AM
