Old 04-04-2010, 05:45 PM
Jim Aldrich Jim Aldrich is offline
XJ Rear Leaf Spring Swap Problems
So, the leaf springs on my XJ were sagging and I thought I would save a few buck and swap them out myself. The problem is that the bolts in the front froze up in the bushing sleeve and I'm pretty sure that on one side the weld-nut in the frame busted loose. I assume I could "hot wrench" the spring eye to be able to get to the bushings and get them off so I can remove the bolt. What in the world do I do for the busted weld nut? I really don't want to take the spring perch off and have to reweld it. is there an easier way?
Old 04-04-2010, 08:25 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: XJ Rear Leaf Spring Swap Problems
Cut a hole in the subframe rail right below the nut to gain access. Heat the nut up a bit and then slip a wrench in to hold it.
Tags
cherokee , leaf , spring , springs
