Old 04-05-2011, 06:50 PM
raiderdanny raiderdanny is offline
transmission
how many quarts of tranny fluid does it take when draining and replace screen or filter in a 2.4 alero Thanks
Old 04-07-2011, 06:53 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: transmission
For both the 4T40E and 4T45E transaxles 7.4 quarts of Dexron III or Dexron VI ATF on a pan drop service.
For checking fluid level see link below.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 04-09-2011, 01:53 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: transmission
Bob if I drop the pan and change the filter, is the pan gasket the formed metal reusable type? Would I be ok to use the rubber type that is included in the filter kit?
Also if I dump seafoam in, how long can I run it with it in there before I need to change it? I wont have a chance to change the trans fluid and filter until probably next week.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-10-2011, 09:09 AM
BNaylor's Avatar
Re: transmission
It should be. I would not use any gasket from any kit but the OE rubber/preformed only. Are you having any transaxle issues? I wouldn't run any Seafoam treatment unless you are. How many miles?
Timeslip 08/12/06
The Following User Says Thank You to BNaylor For This Useful Post:
tblake (04-10-2011)
Old 04-10-2011, 09:24 AM
tblake's Avatar
In God We Trust
Re: transmission
Hey Bob, no just thinking about changing it out as it has 100k and the original owner did absolutly nothing to it as far as preventative maintenance. I thought the seafoam treatment might be a good idea.
Old 04-10-2011, 10:09 AM
BNaylor's Avatar
Re: transmission
Tim, it probably won't hurt. Same process like on our 4T65E transaxles in the Grand Prixs. No more than 8 ounces of "Seafoam Trans Tune" for about 30 minutes drive time.
BTW - Overall the 4T45E transaxle is alot more reliable than the 4T65E. Less overall problems. Just checking the ATF fluid level is a PITA since there is no dipstick.
Timeslip 08/12/06
Old 04-20-2011, 04:58 PM
Re: transmission
2001 alero when i'm driving i here a roar when i speed up gets quiter when i slow down some people say its the hub axle the sound seems to be comingfrom around driver side and in the front i don't seem to have any slap when putting in gear . thanks
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
h22 sh transmission used as a regular transmission h22 Prelude 1 07-31-2004 11:32 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
