Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 05-29-2004, 11:07 PM
85BlueGTI 85BlueGTI is offline
?Transmission Fluid Needed for Manual Transmission?
I have an 85 Golf GTI with a manual transmission. Does the transmission require fluid? If so, what type? And is the fill cap the plastic cap on top of the transmission? Thanks.
Old 05-31-2004, 08:21 PM
boschmann boschmann is offline
Re: ?Transmission Fluid Needed for Manual Transmission?
Yes it takes fluid and no it dosen't go in that plastic cap on top, that is for checking the ignition timing & you will ruin your clutch if you put oil in there. There are drain & fill plugs on the bottom & side respectively. It should be fine using 80W-90 gear oil.
