Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 04-05-2011, 01:19 PM
mywind96 mywind96 is offline
2003 idle problem
Hi all. I have a 2003 expo 4.6L with which I`m having a problem with the Idle speed. The car runs at speed but when idling it starts dying slowly, some times it stays running at so low speed that the battery indicator comes on. Replaced the fuel filter, air filter, took out the IAC and cleaned. Think its the IAC but will like some of your opinions. Thanks. Pat.
Old 04-05-2011, 05:14 PM
tempfixit tempfixit is offline
Re: 2003 idle problem
What happens if you turn the a/c on?? Since you cleaned the IAC, have you tested the IAC solenoid for proper operation?? If it dies with the a/c on at idle the IAC Solenoid is not working.
Old 04-06-2011, 04:52 PM
Thank you very much for your reply. It`s still dying but now i have a code p0506 cel. Idle lower than expected. I guess i`ll replace the iac.once again thanks.
Old 05-04-2011, 03:42 PM
replaced iac valve. Problem solved.
2003 Odyssey Ex Auto 2003HondaOdy Odyssey 2 11-16-2010 09:14 PM
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
