Old 03-30-2011, 01:02 PM
702VegasLife's Avatar
702VegasLife 702VegasLife is offline
Question Cutting in and out
Hey everyone ! My 02 escort just started cutting in and out at lights when at a stop, or in park. It was recently in an accident,(St. Patricks Day) where I had to replace the hood, hood latch, plastic the headlights sit in, headlights, radiator, fan, and the power steering resivor. I had it back up and running in 3 days after the accident. No problems at all. The only thing i didn't replace that i think needs replacing is where the air filter is, the plastic all around it is cracked. I don't know if this has anything to do with the car cutting in and out, but when i come to a stop the car feels like it's going to cut out and die on me. This car is an automatic, I have to hold the brake and lightly keep the rpm's going to keep it running still. I do not have a tack so i'm not sure what my idle rpm's are running at.It just started doing this last night when i was on my way to pick up my girlfriend from work. This is my daily driver and it's shared between me and my girlfriend, so any suggestions or help is much appreciated. Thank you in advance.
Brian
Old 03-30-2011, 01:32 PM
inafogg inafogg is offline
Re: Cutting in and out
if your sucking in unmetered air from cracks, computer will try to adjust
air/fuel ratio.replace/repair air filter housing
Good luck
any codes or cel
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-30-2011, 03:13 PM
Good luck
any codes or cel
No code's, No check engine light. You think that would cause the car to cut in and out like it wants to die?
Old 03-30-2011, 04:20 PM
no,now that i think about it.i guess it be like running without the housing.
air isn't acually measured until it goes through trottle body/maf.
sorry about that.
whats been done lately any plugs filters
did this happen right after accident??
maybe look for a loose ground or even a vacuum line?
how many miles?
Live For Today
Yesterday is gone,
Old 03-30-2011, 06:25 PM
it's got 82,112 miles. It's been running for a week and a couple days since i got it back running.Only thing that's been changed is the air filter, Oil change is coming up at 82,787.
Other than that just the thing's done mentioned above.
Old 03-30-2011, 11:22 PM
Just got home and checked the car, I seem to be losing oil. There was oil on top of the bottom side of the hood, and also after sitting for only 5 mins there was oil leaking from underneath the engine. I also noticed on my way home from work when it starts to cut out really bad like it's going to die the oil light flashes on the dash. No check engine, just the oil light flashes on until I give it gas to keep it from dying. Any suggestions on where to start looking or replacing would be great, this is my only car and I don't have the money to be taking it to a mechanic to have it looked at. Thanks
Brian
Old 03-31-2011, 08:23 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
If it is trying to cut out then the RPM's are so low that your oil pressure is low and the light is coming on. I would say this is normal considering the low RPM's. First thing I would look at is spark plug wires.
Nevada Tumbleweed
Old 03-31-2011, 08:42 AM
JDM 180SX JDM 180SX is offline
I would clean the idle valve/throttle body and check for vacuum leaks
Mobile Mechanic
Old 03-31-2011, 10:05 AM
Thanks, Whats the easiest way to clean the idle Valve/throttle body? better get started on that before I gotta drive to work. I'll keep everyone updated.
Old 03-31-2011, 12:04 PM
vegas,where is the oil leaking from underneath??or is it runing down f/hood
more info on oil on the hood, unless its spraying from something
there should'nt be any on the hood
if its low (from leak)could be related to idle
have you checked oil level?
Live For Today
Yesterday is gone,
Old 03-31-2011, 02:36 PM
I checked the oil level last night when i was waiting for my gf to get off and it was a little low, I topped it off with oil before driving home. The oil is on top of the bottom of the hood...idk how to explain it, It's over by the hood latch, and more towards the passsenger side of the car. For the most part it looks like it's all over the underneath of the hood. I had looked at the car and checked the oil before starting up this morning and it was at the correct level. I started it up with the hood open this morning too see if i could see any leaks or hear anything, I ran it about 10 min to also see if there was any oil spraying out anywhere and i didn't see anything obvious. The car also did not cut in and out like it was going to die at all this morning on my way to work. This has me confused
Old 04-04-2011, 03:03 PM
No answers or suggestions???
Old 04-04-2011, 04:04 PM
badpoor badpoor is offline
Are you sure its engine oil? one of the escorts I owned had a bad nylon power steering line washer and it would shoot up under the hood but not anywhere else.
Old 04-04-2011, 04:14 PM
hmmm.. ya i'm not positive on that.. checked all fluid's and neither oil nor powersteering fluid seem low... But yet that would make sense since in the accident the resivor for the powersteering cracked, and i got a new one from the local picka part took the two lines that attach to it also... I'll have to check it out when i get off work...Now still the engine cutting out like it's going to die?d I'm stumped on that one.
Old 04-04-2011, 04:17 PM
They only thing that comes to mind on the cutting in and out would be defective spark plug wires..i had two sets in a row that would spark but not enough...I'll never buy cheapies again
91' Cavalier losing power up hills and pop noise and cuts in and out mossryan200505 Cavalier Problem Diagnosis 3 05-21-2009 08:15 PM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
Speakers cut in and out code777 Car Audio 3 10-16-2004 08:38 PM
Jetta aircon cutting in and out andreo Jetta/Vento/Bora 1 10-09-2004 09:27 AM
engine cut in and out at 4000 rpms in park coleman Bonneville 2 10-22-2003 05:40 PM
