Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-30-2011, 11:57 AM
jusber15 jusber15 is offline
Exclamation 01 Dakota barely running
I have a 2001 Dakota, 2WD, 4.7L V8. It was running fine with no problems. All of a sudden it started missing and running extremely rough. I barely made it home. I had the trouble codes scanned and this is what they gave me
P0300 - Random cylinder misfire
P0301 - Cylinder 1 misfire
P0302 - Cylinder 2 misfire
P0304 - Cylinder 4 misfire
P0355 - Cylinder 5 coil
P0201 - Cylinder 1 injector
P0051 - Oxygen sensor heater
P0132 - Heated oxygen sensor bank 1 sensor 1 high voltage
P0136 - Oxygen sensor
P0138 - Oxygen sensor
P0152 - Oxygen sensor
P0158 - Oxygen sensor bank 2
P0500 - Vehicle speed Sensor
It is barely running, has a strong smell of fuel. Fuel pressure checked out at 50PSI
I pulled all of the spark plugs to get a better idea of what was going on in there and this is what I found
1- wet with fuel
2- wet with fuel
3- wet with fuel
4- dry but black
5- dry but black
6- damp but not soaked
7- damp but not soaked
8- wet with fuel
I am at a loss with this thing so I figured I would stick it on here and see what you guys have to think.
Old 04-01-2011, 08:25 PM
Re: 01 Dakota barely running
No ideas??
Old 04-01-2011, 08:51 PM
tempfixit tempfixit is offline
My guess is that either camshaft and or crankshaft sensor is failing or the PCM is failing. I would try disconnecting battery for a few hours, then start up to see how it runs and check again for codes. It seems like the timing is off to me.
Old 05-18-2011, 10:35 AM
Still working on this one. So far I have replaced the PCM with a new one, new crankshaft sensor, camshaft sensor, and one O2 sensor. Still same results.
Old 06-12-2011, 02:30 PM
jamesslcx jamesslcx is offline
hi, just curious did you get it fixed yet? interesting problem.
Old 06-29-2011, 07:40 AM
rprough's Avatar
rprough rprough is offline
Make shure it hasnt jumped time. Should be easy enough to check #1 plug at top dead center. Getting too much fuel which means you might have an air restriction also.
God Bless America
Old 06-29-2011, 07:24 PM
hello jusber15, how many miles are on your truck?
HELP, blazer barely runs, dies without throttle Alex01tib Problem Diagnosis 1 10-12-2006 07:44 PM
92 Bonneville, barely runs jusber15 Bonneville 24 05-19-2006 02:59 PM
94 Lumina-Car stalled...now barely running mandodan Lumina 2 11-08-2004 09:34 AM
1996 Cavalier - cylinder 4 misfire, barely runs Steph Engineering/ Technical 4 06-13-2003 02:08 PM
