Im working on a 92 bonneville. will start up for a second, chug, die. give it about 3/4 throttle and it will start and run fine as long as I keep the RPMs pretty high but when I let the RPM drop, it smokes black, chugs bad, misses, etc. Code 41 (cam sensor). Replaced and same results. Any ideas?
Re: 92 Bonneville, barely runs
did you check the interruptor magnet that goes in the cam gear that the cam sensor gets it's signal from? It's a common problem for the plastic retainer that holds it in the cam gear to get brittle and fall apart. This in turn causes the magnet to fall out and trip another cam sensor code.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Does the above symptoms point to a cam sensor problem? By what I understand, the sensor just helps keep everything in time. It seems like at the lower RPMs (2500 and under) its dumping too much fuel.
I looked up code 41 (no distributor pulses/cylinder select error). That would indicate a bad crankshaft position sensor or ignition module, not cam sensor.
I looked up code 41 and the "no distributor pulses/cylinder select error" is for non 3800 engines. 41 for 3800 up to 93 shows camshaft sensor. maybe im wrong. anyways, I changed the crank sensor this morning and it fired up and ran fine (as it has since this problem occured, it will run til it warms up a bit, then cuts out, smokes black bad etc) and then after 3 blocks, it died again. Towed it home once again and swaped the ignition module. Same results. sigh.
Ok when it won't run got spark and injector pulse? Disconnect maf and see what happens.
Ok, today I was digging into it more and I pulled the cam sensor and got a little mirror so I could actually see in the hole. what I saw was a 3 sided piece of plastic...no magnet. the other day when I felt for the cam magnet I must have just been feeling the plastic retainer. I assume this is my problem. Anywho, I have 2 questions. 1. Where do I get a retainer and magnet? 2. Do I have to pull the timing cover and such to replace it?
Well...you can do this: http://6007.us/cammag.htm
Or...yeah, you can pull the front cover off. The magnet is really cheap, 5-10 bucks, and can be gotten at autozone or oreily or similar.
-Eric 89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc. Basic H/C body info:http://www.3800power.bravehost.com/index.htm http://www.cardomain.com/ride/2318168 |
AC-Delco part number on the magnet is 25530386, dealer retail $13.31
Ok, today I tore into it changing the magnet, timing chain and gearset, oil pan gasket, etc and the problem remains. Started right up and ran perfectly for about 5 minutes then chugged and died. Will start up upon placing the accelerator at about 3/4, but runs poorly and wont run in the lower RPMs. Black smoke. Please help me!! Im totally lost now!
Max,it looks like he's not reading your reply or feels he knows whats wrong.
no no, I am reading all posts and taking every bit of help I can get. This is the problem I have now. It dont start at all anymore. After the cam ger,chain, magnet change it started up and ran perfectly for about 5 minutes then sputtered and died. no start. It is firing somewhat. Put the timing light on all the plug wires and spark is irratic and not steady. Injector light is firing normal. Swapped the entire ignition module and coil set out with a set off a running and driving car....same results.
did you disconnect the battery before changing out the sensor?
