Old 03-27-2011, 03:38 PM
helicopter23 helicopter23 is offline
SRS airbag light
97 Grand prix gt
My airbag is fine, I had it tested at a shop. However my srs airbag light is on. How do I disable the light?
Old 04-02-2011, 08:30 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: SRS airbag light
No way via programming at the SRS SDM module that I know of but I guess you could remove the lamp after removing the IP Cluster.
Timeslip 08/12/06
AF Community Guidelines
Old 04-02-2011, 11:22 PM
And how would I do this? Also I have poor electronics (DIC goes bright to dim, etc..) Could this screw up my electrical system more???
Old 04-03-2011, 08:55 AM
BNaylor's Avatar
You mean getting the IP Cluster out to remove the lamp? First part is to remove the dash bezel. See link below for a general idea. You have to really pull on it without breaking it. There are several fasteners holding the bezel in. Then you can get to the IP Cluster.
Click here
Timeslip 08/12/06
Old 04-04-2011, 10:19 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Remember if the light is on, chances are your airbag system is disabled. Thus if you get into an accident, the air bags may not deploy. If I were you, I'd bring it into the dealer and have it scanned with a tech 2 to see what SRS code is present.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-05-2011, 06:17 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Airbags are overrated. I'd rather it if mine didn't work.
Old 04-08-2011, 10:24 PM
Like I said light is on. Does it need to be fixed to pass inspection in NY??
Old 04-08-2011, 10:32 PM
BNaylor's Avatar
For New York state the airbag light is checked during the inspection. However, it is not cause for rejection of the inspection. See link below.
Click here
Your vehicle's Air Bag Warning Lamp will be checked for proper operation. You will be informed if the vehicle's air bag warning lamp is on or is not working. This is an advisement only and not cause for rejection.
Timeslip 08/12/06
Old 04-08-2011, 11:16 PM
Click here
So say my airbag is broke or disabled, the car will still pass??
Thanks
Old 04-09-2011, 10:24 AM
BNaylor's Avatar
Based on what I see it should pass. For example in Texas the airbag light being on will not cause a failure of state safety/emissions inspection either. This is true for most states except the moronic ones.
Whether your airbags work or not is a personal choice IMO. Also, since the airbag light is on meaning a DTC is probably stored in the SDM module airbag deployment will be inhibited.
If you pull the airbag light the most the inspector could tell you is you probably have a burn out lamp. Just to be sure send maxwedge a PM. He used to or still runs a state inspection shop in New York.
Timeslip 08/12/06
SRS airbag light flashes then dies 01gtp23 Grand Prix 8 06-30-2009 11:53 PM
SRS airbag Light pbrenn Grand Prix 1 09-28-2008 02:13 PM
Range Rover SRS Airbag light! jay1558 Range Rover | Range Rover Sport | Evoque 2 01-12-2008 08:57 AM
SRS airbag light is on Luv_my_gp Grand Prix 5 10-30-2006 01:48 PM
SRS Airbag Light on Schister66 '96-'00 Civic 7 02-19-2005 04:28 PM
