Old 03-26-2011, 02:42 PM
pktaske pktaske is offline
ABS light on, TRAC light on, speedometer working at half speed
Pretty self-explanatory. Note that this happened about 2 months ago and went away after a month. Now its back and I figure it's here to stay this time so I better fix it. From all I've read it seems its either the VSS or one of the individual wheel sensors but I'll ask you guys who might have seen this already.
Note that I set the odometer to read speed in mph and it is also reading slow (ie-it's not a mechanical issue with the seedometer).
Thanks...Nick
Old 03-27-2011, 12:58 AM
wiswind wiswind is offline
Re: ABS light on, TRAC light on, speedometer working at half speed
It is sounding like a VSS issue.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 03-28-2011, 07:45 AM
On a 2001, can I get to it through the top of the enginge if I remove the canopy? Any pics would help.
Thanks...
Old 03-28-2011, 09:03 PM
I had mine replaced at a shop, since it failed on a trip far from home.
They accessed it from below, it is sort of above one of the catalytic converters on the back side of the transmission.
Mine is a '96, but I am betting the location of this item is the same on the newer windstars.
This would be an easy repair, except for the location.
If you are feeling around......and grip the speedometer cable.....follow it down to the end.....and you are there.
1996 3.8L Windstar
Old 03-30-2011, 12:06 PM
I thought it was a bit easier on the newer Windstars becasue of the different trannys...maybe not.
ABS and Traction Control Lights on after Jump start jbinramona Seville 5 05-11-2011 09:45 AM
ABS and Traction Control Lights on after Jump start jbinramona Seville 0 06-22-2010 11:11 AM
speedometer works half ass jcdubbu C/K 5 11-01-2006 06:55 PM
Chech engine light / low trac light sassygal5 Grand AM 2 11-28-2004 08:58 PM
1997 GP SE ABS Light and Trac light on chefabbey Grand Prix 2 07-31-2004 12:35 AM
