| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Smoged car didn't pass Knox
What is that, the tech something about my engine running hotter, he said check ur cooling system I added I just changed my radiator but not the cap nor the thermostat?
Just bought the cap and thermostat 2day will be changing them friday! Any help regarding this nox would be gratefully apprecaited by anothe Honda tuner! Trying to keep the Honda alive! I am including a copy of the smog cert!
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!) "Don't trip, skip, pinch your forehead"! 1988 CRX Si 2001 CBR 600F4i Silver & black FAST! 2004 Toyota Tundra (TRD) 2002 dodge grand caravan. |
Smudges!
The top 1 that I failed is 1233 & the 2nd one is 1133.
I spoke with the tech again and he said nox burn at higher temps and is caused when ur engine is worked harder due to runing hotter or timming maybe be off he said it could be more he was just trying to give me a hint of were to look! Does any 1 else know what else I can do to tune it up better?
pour a bottle of "Garunteed To Pass" into your gas tank and run the test again, im sure you'll pass that time.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
The tech is right, NOx forms under high temp, but there could be alot of things that causes it.
Does your car has mods, if so, what are they? Is your engine running hotter than it suppose to? You said you put in a new radiator, but is it's valume equal or higher than your original one? You can try putting a lower temperture thermostat (always make sure it is a fail safe thermostat) and that may help to bring down the running temp. If your engine has EGR, you should check to see if it's working also since the EGR has alot to do to cool down the cyclinder temp. Does anyone here know if the 88 CRX Si has air injection into the cat? PS. Was the car tested on the dyno when being smog?
Power is nothing without control The fastest driver is the one with skills 95 Civic EX 83 Toyota Starlet 07 Ducati Monster S4RS |
now where can i obtain this? :flash:
an automotive store should carry it, i think it was 9.99 last i saw it.
but you still may wanna find out why the car is failing that test.
Man sheesh!
The bottle of Guaranteed to pass is 8.99 at Kragen.
Yes they put it on the Dyno, Sucks! My car has no mods what so ever, same size radiator with new radiator cap and new thermostat! The EGR valve not sure what that is and were it is located! Thanx guys really appreciat the help , still stressing its this saturday @ 8:30 am i have to go back and re-smog. Since my tags expire the end of this month!
good luck.
Sad News!
Well I didnt pass, I poured in a bottle of the gauranteed to pass, set back my timing I faled again it only lowered me a little no enough to pass tho!
I will be trying to get a repar cost waiver wich will delay me smoging the car for up to 2 years but the catch is I must spent a minimum of $450 in a smoged licensed repair shop. So more money to the spend! Mr Gray Davis thanx for the new Dyno smog test's! I passed the regular smog but not the new enhanced smog!
if i remember my auto store job, the Gauranteed to pass people will pay for your smog check if you dont pass after using their product, thats why its gaurunteed, but i hope you get what has to be done, and all works out ok.
I found something that might help, its kinda like Guaranteed to Pass, but it has somg reports to prove it, heres the link
PureGas emissions test fuel catalyst Problem is it comes in 55gal drums or a 5gal pail. 5gal pail sounds more realistic, and you have extra, so when your friends dont pass, you can charge them for the additive.
Judge not, lest you be judged first |
If it's gonna cost you a lot to get it fixed and you have a lot of mods (some of which may be illegal) just don't get it done. I mean the only way you really ever get pulled over for inspection is if you commit a moving traffic violation. Just be sure to watch out for charlie check points (sobriety stops) and you should be fine. I was pulled over once and if you aren't an ass the officer usually cuts you a break...just be friendly and weird and they won't even bother you (ask him if you can get a picture of you in hand cuffs and getting hit by a night stick or something funny). Mine is almost a year overdue and they don't give me any flak unless I am tearing around. My car won't pass because of the suspension work (technically you can't have anything on your car that wasn't put on at the factory, so my lowering springs and struts won't cut it). And I'll be damned if I'm going to put my old springs back on with 17's...my Accord would be a fuckin' truck.
remember to keep it tucked between your legs (if ya wanna pretend you are a woman) You can find me at ImportRuiner.com |
What kinda BS is the Goverment doing you cant pass a smog or inspection cause ur car is lowered damn pricks!
What about the lifted trucks or the loud as harleys rolling around, since it isnt american they dont let the rest pass! Usuall punk ass goverment!
Re: Smoged car didn't pass Knox
I'm having somewhat of the same problem, I tested 4 times and didn't pass. But I did get the Nox to go down from 1200 to 440. I used sea foam, to clean out the carbon build up in the combustion chamber.
This can be purchased at Napa for 6.99 I think. Here's a link on how to use it: http://diyimports.com/seafoam.html Edit: You might want to replace the O2 sensor and cat. |
