Hard starting
1996 K1500 4x4 w/350 struggles to start when cold you have to crank and crank over and over until it finally fires when it's running it keeps running perfectly has lot's of power can drive for miles. If you let it set for two days you have to crank it three times when you let the key of on the third or fourth try you hear the pump run then it starts right up. But if it sits for a week or two it is almost impossible to start. This vortec 350 has 15,000 act miles on it. It's like new! I think it's the fuel filter or possibly the ground wired that hooks to the frame on the drivers side what do you think?
I have a 98 Plymouth voyager 91 Honda civic 83 and 94 Chevy diesel van 71 Monte with a trophy I got at super Chevy Sunday 68 ford 88 CRX HF. I'm from Muskegon Michigan! I'm a state certified mechanic and I have worked on all kinds of cars and trucks. |
Re: Hard starting
As you mentioned, it could be the ground wire for the pump, or it could be the pump itself is faulty, or not getting battery voltage consistently. The ground wire at the fuel pump module should less than 5 ohms resistance to ground at all times. The grey wire at the pump module should show battery voltage for 2 seconds when the key is turned to the RUN position, (engine off) and continuusly when in the START position. Post your results.
You have to know how it works, to figure out why it doesn't. |
| The Following User Says Thank You to old_master For This Useful Post: | ||
302NOVA (04-29-2011)
Re: Hard starting
i would check fuel pressure it sounds like low f/pressure
post with the pressure readings you get
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
Re: Hard starting
Sounds like the fuel pump is allowing the fuel to drain back to the tank, so you are having to re-prime the fuel system. If that is your problem you will have to replace the pump.
NO 4 N JUNK ![]() 1994 GMC K1500 XC 5.7L 2008 Chevy Impala LTZ |
| The Following User Says Thank You to horse482 For This Useful Post: | ||
Re: Hard starting
That or the fuel pressure regulator was my first gut instinct.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: Hard starting
Do you think it is posible that the fuel is leaking out of the fuel injectors? So I'm having to refill the injector lines with fuel? I have a new fuel pump that I'm going to install first.
Re: Hard starting
imo no,or you'd have a no/hard start because of flooding
check the system for a leak down or did you already realy need to check all the pressures before you do anything
Re: Hard starting
leaking/dirty injectors, fuel regulator leak, or fuel pump check valve or not enough pressure on cold start. you need 60-65 psi I believe with this year engine. the fuel filters should be replaced every 30,ooo miles. cut open to see if this is correct for you . poor start can be a bad ECT this can trick the computer to think the engine is hot..If so the injector on time is shorter than a cold start ! |
Re: Hard starting
I installed the new fuel pump. I cycled the pump about six times then I hit the key to start it and it fired instantly after sitting for a month!! Problem solved!! It has a new fuel filter and new plugs too!!!
Re: Hard starting
keep fuel above 1/4 tank to prevent the pump from damage ! |
| The Following User Says Thank You to j cAT For This Useful Post: | ||
302NOVA (05-30-2011)
