Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 03-22-2011, 08:52 PM
userpete1037 userpete1037 is offline
Smile Water Pump Cover
I'm experiencing a slight leak at the water pump cover. Before anyone say it's the water pump, it has been changed. My question is do suppose to put some sealant around the seal on the cover or is suppose to automatically seal?
Old 03-23-2011, 05:19 AM
caddydaddy caddydaddy is offline
Re: Water Pump Cover
What year and engine do you have?
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 03-23-2011, 04:40 PM
It's a 97 Cadillac Deville, Northstar (V8).
Old 03-23-2011, 06:10 PM
There is an O-ring gasket on the pump itself that seals against the housing. On the black steel thermostat housing there is a gasket. Which side is it leaking at?
2000 Cadillac STS
Old 03-23-2011, 07:57 PM
I'm going to assume it's leaking at the outer part of the pump because there is a slight drip where you screw the cover back on.
Old 03-23-2011, 08:07 PM
If it is the thermostat housing, I'd replace the gasket if it hasn't already been done. If the thermostat itself hasn't been replaced, now is the perfect time to do it!
2000 Cadillac STS
Old 03-23-2011, 08:14 PM
I'll give that a try then. Thanks.
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
