Old 03-20-2011, 02:49 PM
silveralpha silveralpha is offline
1993 chevy 1500 tailite and dash lights keep blowing fuse
As i have no taillights this needs to be attended asap. Every time the fuse is replaced it blows almost immediately even when replaced with a larger fuse. There is no problem with any other fuses in the panel or known electrical problems in the truck. Its a safety issue, and I'm convinced its a simple fix but don't know where to start, any suggestions?
Old 03-21-2011, 10:51 AM
muff34 muff34 is offline
Re: 1993 chevy 1500 tailite and dash lights keep blowing fuse
You have a short in the wiring somewhere. look at wiring at front and rear lights for a bare wire. have a good look at the bulbs as well. I had a bulb go bad years ago and it kept blowing fuses. Boy was that a head scratcher...lol.
Life Is A Highway ,Enjoy The Ride
Old 03-21-2011, 11:07 AM
brcidd's Avatar
brcidd brcidd is offline
First place to look is at any trailer connector harness- see if anything is amiss in that area if you have it.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-21-2011, 04:50 PM
777stickman 777stickman is offline
In addition to this you may have a headlight sw issue if it's blowing the fuse with the sw off. Do Not use bigger fuses when trouble shooting as you can easily fry some wires.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-21-2011, 05:28 PM
jrecken jrecken is offline
Had the same problem with my wifes Tahoe and it was the pigtail for trailer connection.
Old 03-21-2011, 07:00 PM
j cAT j cAT is offline
rather than using a fuse , use a 12volt lamp. when the lamp is bright this would be a short circuit. when the lamp is dim the short is removed. place this across the fuse socket . having long wires attached to the lamp[bulb] you can monitor this as you check the wire harness /etc.....
brake lights keep blowing fuse mthaner Elantra | Avante 1 06-23-2004 04:43 PM
1993 D caravan's running lights keeps blowing fuses! smooth4you_1975 Caravan | Voyager 1 05-18-2004 07:12 PM
hazard lights keep blowing fuses afcro Lumina 0 10-26-2003 10:08 PM
Dash lights keep blowing fuses crx_insanity '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-22-2003 05:31 PM
