Old 03-19-2011, 09:23 PM
jel08270 jel08270 is offline
1981 c20 tbi swap no injector pulse HELP!!!
I just installed a used Tbi on my 1981 c20 5.7,from a 1990 suburban 4x4 1/2 ton.My problem is it cranks over and will only start if i pure fuel into the throttle body and run for a second then stall out,I have 12 volts going to the injectors when the key is on.but it won't start.Do you think this ECM has a VATS thats causing me a problem?The Tbi did work well in the suburban before i took it out.I also tried another ECM out of a running 1990 chevy 4x4 pickup with a 5.7,still no pulse but still got 12 volts to the injectors,some how im not getting a ground? I unplugged the injectors and hook up a 12 v light to it,cranked the motor and the light wouldn't work.
Old 03-19-2011, 10:06 PM
madcatter madcatter is offline
Re: 1981 c20 tbi swap no injector pulse HELP!!!
Maybe a dumb question but what's your fuel pump doing? I assume you swapped out sending units and so forth but do you have fuel pressure?
Also, when checking the injector pulse without a noid light, use an LED for it's speed and low resistance.
-N8
www.kowboykustoms.com
Kowboy Kustoms trick paint
Old 03-20-2011, 12:06 PM
Hi Madcatter I installed a external electric fuel pump and filter to the original fuel lines I have fuel to the TBI,but I need to check how much pressure is going to the throttle body,the fuel pump says it max is 15 pounds,but i will check it when I get back from my sons Soccer game.There is fuel coming back to the Fuel Tank from the return line I can see that,but do you think low fuel pressure can stop the injectors from pulsing?
Old 03-20-2011, 02:40 PM
I'd say 15psi should be just fine IF that's what's actually getting up there. Also, the pressure regulators are known for going bad, especially the spring. Cheap and easy fix though but you'll have to pull the throttle body and disassemble it to find out. There's lots of info on this procedure out there. I just did it last week on my '90.
-N8
Old 03-20-2011, 09:28 PM
Hey MadCatter Thanks for your time,I got it running,I needed 12 volts to the orange wire in the Harness and it fired right up.Don't know how I miss that one.
95 S10 4.3 No injector pulse Help Please !!! Roger Dale Problem Diagnosis 12 05-05-2009 08:26 AM
No Injector pulse in K-5 Blazer 87 TBI rhett3147 Blazer 0 02-28-2005 07:26 PM
No injector pulse TBI BobM46128 C/K 8 10-27-2004 06:35 PM
Hybrid 91 civic B18 swap no start, no injector pulse, please help SouthSideCustoms '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-26-2004 02:43 PM
350 Tbi No Start No Injector Pulse 1snake C/K 2 09-03-2004 11:50 AM
