Old 03-19-2011, 05:09 PM
cccote cccote is offline
Unhappy Dodge Caravan 1990 doesn't shift after car gets warm
Hello All
I just got a Dodge Caravan 1990, 3.3L 6cyl and my problem is that it will not shift into higher gears once it has warmed up. When I first start it (cold) it will shift just fine, no noise, no hard shifting nothing wrong at all, then after a couple of miles (1 to 2) it will lose the gear and I'll be driving in 2nd from then on. If I shut the car off and back on while it is still warm it will not go into any higher gears either. This is the same all the time, which makes me think it is a electrical problem, but what electrical part could cause this? Or am I wrong and is it not electrical?
I am great full for any suggestions anyone may have, thank you.
Old 03-19-2011, 06:28 PM
aleekat aleekat is online now
Re: Dodge Caravan 1990 doesn't shift after car gets warm
Cheapest thing to do is change the tranny fluid and filter if it has one.
The Following User Says Thank You to aleekat For This Useful Post:
cccote (03-20-2011)
Old 03-19-2011, 06:58 PM
Thanks, that is something that has already been done, and the fluid level is fine when checked. Also added some Trans X but that did nothing at all.
Old 03-20-2011, 01:29 PM
b1lk1 b1lk1 is offline
You're stuck going to a tranny shop as there is nothing you can check if you don't know that transmission. It is an OBD system with no feedback to the PCM/ECM. It could be a solenoid issue, but you require special tools to test line pressures and such.
The Following User Says Thank You to b1lk1 For This Useful Post:
cccote (03-20-2011)
HELP! 92 Ranger doesn't want to move when warm!! fordstranger Ranger | Courier 3 07-16-2009 07:33 PM
1994 Dodge Caravan wont start anymore after IOD-Fusing and Batterie-Change andiheinz Caravan | Voyager 1 02-13-2006 06:06 AM
dodge pickup transmission,no shift after 20 miles johnny74839 Ram Pickup | Ram SRT10 10 02-28-2005 08:40 AM
2003 Caravan 3.3 Noise After Engine is Warm Marc123 Caravan | Voyager 0 01-20-2004 08:13 AM
Dodge Caravan 1990 3.0L David Hill Caravan | Voyager 3 12-27-2003 09:29 PM
