Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-21-2005, 09:59 AM
johnny74839 johnny74839 is offline
Send a message via Yahoo to johnny74839
Question dodge pickup transmission,no shift after 20 miles
shifts normal first 20 miles till it warms up,then won't shift at all,help!
95 dodge 1500 ,3 speed with overdrive.
Old 02-25-2005, 10:03 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: dodge pickup transmission,no shift after 20 miles
How many miles on the truck?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-26-2005, 08:46 AM
125,000,rebuilt changing all bands and clutches,recently.
Old 02-26-2005, 11:09 AM
Hate to say it, but I'd look there then, since recently rebuilt. Did the problem exist prior to the rebuild?
If not, it sounds like some pressure may be being sent in reverse; some trannies won't shift into OD until warm. Since yours shifts fine until warm, sounds backwards.
Old 02-26-2005, 02:39 PM
Re: Re: dodge pickup transmission,no shift after 20 miles
yes ,did do it before rebuilt,but clutches slipped
Old 02-27-2005, 08:45 AM
OK so didn't shift after 20 mins even BEFORE the rebuild?
I'd have to say I'm not sure and I'd be going to a trans shop, even though expensive. Once they're done you shouldn't have to worry about the trans for as long as you own the vehicle.
Old 02-27-2005, 08:53 AM
does a dodge transmission pump fluid while it's in park
Old 02-27-2005, 09:08 AM
Yep; the trans fluid not only performs the shifts, but provides the internal lubrication for the tranny.
Old 02-27-2005, 09:29 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
But does a dodge transmission pump fluid while it's in park? I don't think it does does it? Only when the truck moves right?
My Mopars
Old 02-27-2005, 11:56 AM
troy1 troy1 is offline
AF -Advisor
The pump is still pumping but the converted is not getting charged thats why you have to check it in "N" If some one puts a transgo shift kit in like I do then you can check it in park because of the new manual valve and holes being drilled in the Valve body. Now the converted is charged at all times help so it does not wear out the pump bushing
Old 02-28-2005, 08:40 AM
i was wandering because in nov. last year i check fluid level,fluid was about a half a quart over full so i disconnected line at radiator to drain,started truck nothing pumped out till i put it in gear,u would think it would pump at all times even in park to keep tranny cooled off,and to keep every thing lubricated
