Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 03-19-2011, 08:40 AM
badapple7 badapple7 is offline
2003 upper engine noise
Yesterday I started the car and there was no upper engine noise. By the time I got to work, there was a lot of knocking that sounded like valve train noise. I thought it may be a collapsed lifter, but it sounds like it is coming from both sides of the motor. It sounds like it is not getting enough oil, but the oil level is fine. Today it was not present when I started the car, but came back after it warmed up. It has a 2.7 L engine. Anyone have any ideas?
Old 03-19-2011, 09:24 AM
inafogg inafogg is offline
Re: 2003 upper engine noise
could be oil pressure drop after engine warms up.
you could check it leaving gauge installed(need extra long hose)
how many miles??how often is oil changed??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-19-2011, 09:25 AM
Scrapper Scrapper is offline
AF Premium User
do a compression check on it. also it could be knock sensor also and is your oil black?
The Following User Says Thank You to Scrapper For This Useful Post:
badapple7 (03-21-2011)
Old 03-21-2011, 07:31 PM
I changed the oil every 3-4 thousand miles. I have parked the car but it seems to be starving for oil on the top end when I start it up (oil is cold). I am a GM guy and am new the Dodge motors. I am going to check the oil pressure this coming weekend. Is it typical for the oil pump to go out on these cars. I had heard sludge buildup was a problem. Maybe some sludge got pulled into the pump?
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
sudden alternator whine - stock 2003 yukon 4433bryanc Yukon 5 09-22-2009 12:27 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
