Old 03-18-2011, 08:07 PM
famzapata famzapata is offline
Water pump replace Win 95
I have a Win 95 3.8. and I need to replace the water pump, does any body could tell me how to do it ? or where can I see pics or videos ?
Old 03-18-2011, 09:10 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Water pump replace Win 95
Hola!
This comes from the service manual:
WATER PUMP
Removal
1. Disconnect negative battery cable. Drain cooling system. Loosen drive belt tensioner, and remove drive belt. Raise and support vehicle. Remove lower radiator hose. Remove lower nut on both front engine mounts. Lower vehicle. Remove generator. Position drain pan under power steering pump.
2. Using Fuel Line Separator (T90T-9550-S), disconnect power steering pressure line from power steering pump. Remove power steering pump filler cap. Disconnect necessary coolant hoses.
Attach lifting eye to front exhaust manifold. Attach engine lift to lifting eye and lift front of engine 2" (51 mm).
***You can either do this or raise the engine by loosening the engine mount bolts and using a floor jack***
3. Remove water pump pulley. Remove drive belt tensioner pulley from power steering pump bracket. Remove power steering pump bracket with power steering pump attached, and position aside. Remove water pump bolts and nuts. Note bolt location. Note if sealant is applied to bolt threads. Remove water pump and gasket.
CAUTION: When bolt is removed, note if sealant is applied to threads. Some bolts are coated with sealant to prevent coolant leakage.
Installation
1. Install gasket using Gasket and Trim Adhesive (D7AZ-19B508-B). To complete installation, reverse removal procedure. Lightly oil threads of bolt and stud not containing thread sealant.
2. If bolts originally contained thread sealant, clean and reapply thread sealant to bolts. Tighten bolts and nuts to specification (15-22 ft lbs). Fill cooling system.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 03-19-2011, 09:22 AM
wiswind wiswind is offline
Tough part is lifting that end of the motor.
Reason, if you look at the pump location, there is a unibody frame member inline with where the pump needs to go, you need to lift the motor enough to get the water pump shaft to clear that unibody frame member.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
Water pump replacement.. and upper brake light/bar/LED replacement vballfun Blazer 4 05-12-2005 08:49 AM
95 blazer water pump replacement? flytem3 Blazer 2 08-29-2003 07:06 AM
Water pump replacement on E30 spikedjax 3 Series 2 07-17-2003 05:54 PM
water pump replacement Steve A Integra 2 06-19-2002 12:02 PM
