Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 06-10-2003, 12:15 PM
spikedjax spikedjax is offline
Water pump replacement on E30
Hi guys,
after 3 hours of messing around I found out that the reason I'm loosing coolant from my 3.25iSport is cos my water pump is up the shoot. I know it's not expensive to replace and I've got a Haynes for it, I'm just wondering if anybody has done this job before and has got any useful tips ?
It's not the speed that bothers me it's the sudden stop at the end!
Old 06-23-2003, 10:31 AM
mcanales mcanales is offline
Depending on the age of your car consider changing the timing belt also. And if your hoses are old change them. Yes were talking a few more bucks but it's cheaper than breaking down on the side of the road. As far as tips go get the special tool (spanner wrench) to take off the fan/clutch assy. It is earier to do all of this work with the hood removed but not at all necessary.
Old 07-17-2003, 05:54 PM
BMWTECH BMWTECH is offline
Mccan is right all except the hood part. You can remove the kidneys(center grille) and disconnect the hood shocks. This will allow the hood to open further.
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
Water pump replacement.. and upper brake light/bar/LED replacement vballfun Blazer 4 05-12-2005 08:49 AM
Water Pump Replacement Cost CBackus2001 Passat 2 12-26-2003 08:18 PM
95 blazer water pump replacement? flytem3 Blazer 2 08-29-2003 07:06 AM
water pump replacement Steve A Integra 2 06-19-2002 12:02 PM
