Old 03-18-2011, 05:00 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
is this supposed to be empty? 2002
I have a 2002 grand caravan sport 3.3 6cyl I have a check engine light code po456. So after looking around these forums I started looking under the van checking the lines. Should this spot have a hose coming off or something?https://picasaweb.google.com/lh/phot...eat=directlink it is next to this box https://picasaweb.google.com/lh/phot...eat=directlink
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 03-19-2011, 03:09 PM
Alphabravo Alphabravo is offline
Re: is this supposed to be empty? 2002
That big box looks like the canister, my '03 does not have that little thing next to it, otherwise I'd tell you if something was there or not. It looks like nothing was ever connected to it, because of the consistency of color. If it had a hose connected to it at one time, you would notice a difference from where the hose was as compared to the rest of the unit. P0456 is a small evap leak, if something was supposed to connect to that thing and fell off I would imagine is would set off a large evap leak code. I would look for small cracks in those hoses. If you can't find any try another gas cap. or maybe even your gas cap is fine and it wasn't tightened all they way the last time you had it filled.
Good luck.
The Following User Says Thank You to Alphabravo For This Useful Post:
chevyn0va1 (03-20-2011)
Old 03-19-2011, 03:53 PM
b1lk1 b1lk1 is offline
No, there is not supposed to be anything connected to it. It is basically a vent. My 2002 has the exact setup with that being open.
The Following User Says Thank You to b1lk1 For This Useful Post:
Old 03-20-2011, 12:58 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Here is a video explaining how an EVAP leak is troubleshot using a smoke generator. It shows the likely leak points. http://www.youtube.com/watch?v=CSn0ljUS6kI
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
Old 04-07-2011, 12:21 PM
chevyn0va1's Avatar
can one rent this?
Old 04-07-2011, 01:35 PM
danielsatur danielsatur is offline
You can use cigar smoke to blow into the Evap system!
Caution - Keep lighted cigar away from the Evap system and car, gas vapors are very
explosive.
It's probably worth $80 for diag to pinpoint your Evap problem.
Suspect bad rubber, plastic, or seal.
1) Check the rubber seal around your gas cap 1st, it has the most wear + tear.
The Following User Says Thank You to danielsatur For This Useful Post:
chevyn0va1 (04-07-2011)
Old 04-07-2011, 04:45 PM
Another common leak spot is under the airbox, the evap lines.
The Following 2 Users Say Thank You to b1lk1 For This Useful Post:
chevyn0va1 (04-07-2011), Xusn96 (03-04-2017)
Performance Parts for 2002 Blazer ls Jandreau Problem Diagnosis 2 04-12-2009 04:28 PM
Anything to look for before buying 2002 GT convertible? jimhockey74 Mustang Talk 0 02-12-2009 02:19 PM
is this supposed to be this hot (exhaust)? perna00 Eclipse 2000+ 21 09-25-2004 01:39 PM
What kind of honda is/was this supposed to be??? j.fuggi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 02-22-2002 01:21 AM
