Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 09-08-2004, 12:52 PM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
is this supposed to be this hot (exhaust)?
i just put headers, cat, and cat back on my car. i've noticed that the exhaust is extremely hot coming out of the exhaust. i don't mean like "wow that's hot", i mean like seriously burn the ^%$# out your hand hot. the outside of the tip is hot enought to sizzle and deflect any water that even comes close to it even after it sits for a few minutes. it is supposed to be this hot? does this also mean i'm running either to rich or lean? any info is helpful. thanks
Old 09-08-2004, 01:42 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: is this supposed to be this hot (exhaust)?
so you let your car run for a few mins and then walked around and grabbed the exhaust tip??
Old 09-08-2004, 02:07 PM
perna00's Avatar
one of my friends was walking around the car checking it out and the exhaust gasses reached his leg making his jump back. he commented on how hot it was so i checked it out. i then turned the car off for a few minutes and even dropped some water on it to see the reaction. although, feel free to come over and grab it if you'd like though.
Old 09-08-2004, 03:21 PM
i was just about to hand you your sign
Old 09-08-2004, 03:25 PM
perna00's Avatar
i take it you don't know about the actual question though?
Old 09-08-2004, 04:52 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
not a clue here, best suggestion is could get if ur wondering rich or lean, get a A/F ratio gauge, thats what i'm planning on doing when i get my new intake put on
Don't act like you don't love it.
503/2000
Old 09-08-2004, 06:53 PM
i wouldnt think that running lean or rich would make your exhaust any hotter. but i could be wrong
Old 09-08-2004, 08:04 PM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
Running lean would make the exhaust that hot. And it is not a good thing either. I suggest an EGT, not A/F gauge (just blinky lights) to give you a more consistent readout of your exhaust temps. Also, the EGT is able to give you your A/F's, just not like 12.5:1, 12.0:1; but more in temps. The lower the EGt, the richer you are running and the higher, the more lean you are running.
Old 09-08-2004, 08:37 PM
perna00's Avatar
so where exactly does the exhaust temp fit as far as testing is concerned? guess i should probably get that e-manage and tune done pretty quick.
Old 09-08-2004, 08:38 PM
perna00's Avatar
oh yeah, i forgot to mention that my headers change from a gloss chrome look to a brilliant gold color.
Old 09-08-2004, 08:47 PM
Sleepr awd's Avatar
niiiiccceee....
503/2000
Old 09-08-2004, 09:01 PM
perna00's Avatar
. . . not temp wise
Old 09-08-2004, 10:18 PM
i thought that color changing was a bad thing?
Old 09-08-2004, 11:21 PM
Sleepr awd's Avatar
oooo well crap then...iono i think it would look cool but i didn't think about the structuralness of it it most likely won't hold up long if u keep doing that to it
503/2000
Old 09-09-2004, 08:45 PM
crazy_ugly_coyote crazy_ugly_coyote is offline
Banned
Send a message via AIM to crazy_ugly_coyote
ur headers will change like that in most cases. if u ever had a performance quad or motorcycle you'd notice that right away when u put on an aftermarket pipe. one way to stop that is to clean it with windex. i dont know exactly what it does but it sure works. as for your high temps... u might want to see if ur cat is still good. that might be the problem. then again... just go to your dealership. most of those guys have been screwing with cars since they were old enough to pick up a screw driver.
