Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 03-16-2011, 02:13 AM
JOHNSJ22 JOHNSJ22 is offline
Driver Side Impact Sensor (Airbag)
My 2002 Lincoln LS has an airbag light on and is showing a code for the driver side impact sensor. Can anyone tell me where this is and whether or not I should attempt to fix it myself or take it to a professional? Also, any important steps to take would be appreciated.
Thanks,
Jac Johnson
Old 03-16-2011, 07:44 AM
gcwimmer gcwimmer is offline
Re: Driver Side Impact Sensor (Airbag)
You might want to check the airbag wire/connector under the driver's side seat, common failure with the seat being moved back and forth fatigues with time.
Old 03-16-2011, 08:09 AM
joegr joegr is offline
Thanks,
Jac Johnson
I don't have 1st gen data, but the 2nd gen has two side impact sensors on each side, one in the B pillar, and one in the C pillar. Both are near or just below carpet level. These tell the airbags to deploy and activate the explosive seat belt retractors. If you are not 100% certain about how to correctly replace them, then you should probably get a dealer to do it.
automatic locks and driver side window not working rmwilson Problem Diagnosis 5 06-23-2010 08:04 AM
Lincoln LS Side Impact Collision (2000-2003 models) jmt314 LS | MKZ 1 06-20-2009 12:59 PM
Sensors in Driver side head 1990blackgt Problem Diagnosis 6 12-18-2007 08:52 AM
Grrrr...Driver side door sensor? -stev=o 4Runner/GX470 3 06-20-2007 10:47 AM
