Old 12-17-2007, 02:48 AM
1990blackgt 1990blackgt is offline
Sensors in Driver side head
Hey- I have a 95 blazer with a vortec. when replacing my head gaskets, i broke one of the sensors in the driver side head. It's the lower sensor underneath what looks like the knock sensor. The passenger also has the upper knock? sensor but nothing else. If I had to guess, the lower (broken) sensor looks just like the coolant temp sensor in the front of the engine. Any help would be great. Thanks.
Old 12-17-2007, 08:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Sensors in Driver side head
Knock sensor.
Can you get to it to drill out.
Look on old head.
Does it screw into the water jacket or just a thread hole?
MT
Old 12-17-2007, 12:50 PM
Originally Posted by MT-2500
Knock sensor.
Look on old head.
I can screw it out. it's under the knock sensor.
Old 12-17-2007, 01:11 PM
MT-2500's Avatar
AF - Advisor
Was it a sensor with wire or wires on it?
If so and you can get it out replace it replace it.
MT
MT
Old 12-17-2007, 09:35 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
This sounds like the coolant temperature gauge sensor, if I am not mistaken. The one in the front of the engine is for the ecm(yellow/black wires) the other one in the head is the guage sensor (green wire if I remember).
Old 12-18-2007, 02:18 AM
Sounds right!! is it the same sensor as the one in the front of the engine?? My auto parts store only has a listing for a coolant temp sensor....
Old 12-18-2007, 08:52 AM
MT-2500's Avatar
AF - Advisor
Tell them it is for the dash gauge.
They should list two different ones.
One for pc and one for dash gauge.
Match it with the plugin on your wiring harness.
If they can not give you the right one find another parts place or go to the dealer.
Sometimes it is a dealer ideam.
And Some times dealer OEM are better and sometimes cheaper.
Good Luck
MT
MT
