Old 03-14-2011, 04:06 PM
roman1978 roman1978 is offline
2005 Grand Prix Steering wheel replacement
I have 05 GP and i want to replace my leather steering wheel its worn. Anyone know how to remove the airbag do I need any special tools also I see the 06 and up wheel is different it does not have cruse build on it. Can I use the 06 wheel and use my own craze switch on it I see them on eBay really cheap.
Old 03-14-2011, 08:35 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 2005 Grand Prix Steering wheel replacenment
There should be a cover or covers at the back of the steering, that's where the airbag holding nuts are located.
Please BE VERY CAREFUL when removing it, you should disconnect the battery for 15 minutes before you start working on the system. The airbag should be stored facing up and whenever you need to handle it always do it with the from facing away from you.
Always make sure the wheels are in the straight position and you note the position of the clockspring (the wiring that connects the horn and controls to the steering column), if you install it in a different angle you might damage it.
I don't know if wheels are interchangeable, hopefully another user will comment on it.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 03-15-2011, 10:03 AM
I also want to know if i can use a steering wheel from 06 and up GP
Old 03-18-2011, 01:58 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2005 Grand Prix Steering wheel replacement
Do you have the radio/CD controls on the steering wheel?
Timeslip 08/12/06
AF Community Guidelines
Old 03-18-2011, 09:30 AM
Yes i do have the buttons its a GTP model
Old 03-18-2011, 02:25 PM
BNaylor's Avatar
Is there a big difference in the way the steering wheels look on the '04-'05 GPs versus '06 and up. Mounting wise it should be the same. Not sure electrically since I only have '08 GM wiring diagrams. Send a PM to Richtazz and he can double check for you to be sure.
Timeslip 08/12/06
Old 03-18-2011, 04:29 PM
olopezm's Avatar
Electrically speaking the wheels won't match, I just checked the diagrams and even though the audio controls have the same color keying, the cruise controls are different, for the '04-'05 they are mounted on the steering wheel while in the '06 are mounted at the multi function turn signal lever.
Sorry that I didn't think about it before...
Oscar.
Old 03-18-2011, 09:57 PM
BNaylor's Avatar
Good research Oscar. Glad you had the time to do it. On my '08 GXP the cruise controls are on the stalk.
Timeslip 08/12/06
Old 03-18-2011, 10:22 PM
olopezm's Avatar
Thanks Bob, I try to give back as much as I've received from the forum!
Old 03-22-2011, 12:15 AM
My question is if I can remount the cruse swich on to the steering wheel forom 06 and just connect the vires. I am assuming there is a plug connector for cruse
Old 03-22-2011, 11:57 PM
olopezm's Avatar
I've uploaded the diagrams for you to see them, I don't think you'll be able to rewire them, the 05 GP uses the BCM and PCM for the cruise control to work. 06 GP only uses PCM and depending if you have the 3.8L or 5.3L the system uses 2 or 4 wires...
Oscar.
Old 03-23-2011, 09:08 AM
thanks for the diagrams
Old 03-24-2011, 02:23 PM
olopezm's Avatar
You're welcome!, I hope you get it to work and post back your results.
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 11:20 AM
Steering Wheel Replacement john3mo Lumina 2 08-25-2010 01:52 PM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 09:57 AM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 01:55 PM
89 grand prix steering wheel removal ksuwildcats2004 Grand Prix 1 07-14-2004 03:52 PM
