Old 03-14-2011, 11:33 AM
mwid73 mwid73 is offline
93 silverado 4L60E problems
Hi guys,
I have a 93 silverado with 207,000 on it. Recently, It has been shifting hard into reverse and drive from park or nuetral. By shifting hard I mean it is "clunking" or "jumping" hard into gear. Almost as if you were holding the accelerator at a high rpm while shifting from park but it is at normal 700 rpm idle speed. Occasionally, it will also shift just a little bit hard from 1st to 2nd while increasing speed. Otherwise, everything else seems to be normal. Fluid level is fine and it's only got around 10,000 on it since I last changed the tranny filter. Any ideas??? I don't really want to spend the $$ on a rebuild since it's just our old farm runner but I do still love the old rust bucket and it is what's used for all our "dirty" work....
Old 03-14-2011, 01:46 PM
j cAT j cAT is offline
Re: 93 silverado 4L60E problems
Originally Posted by mwid73 View Post
Hi guys,
lift wheels off ground and rotate drive shafts to check the U joints.
Old 03-14-2011, 02:16 PM
I replaced both U-joints on the rear shaft at 199,000. I'm pretty sure it's in the tranny. But, I'll check the joints for defects just to make sure....
Old 03-14-2011, 05:35 PM
only use USA Ujoints...chinese are not working good.
many times new U joint can get damaged or hardware issues.
if the transmission had worn parts I would expect shifting problems ..
check the motor mounts especially driver side and the tranny mount.
Old 03-14-2011, 05:47 PM
kahjdh's Avatar
kahjdh kahjdh is offline
sun shell fracture? would explain 2nd and reverse
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 03-20-2011, 10:40 PM
transman618 transman618 is offline
Not likely the sun shell since 2nd and reverse are still operational. I would first scan the computer for any trouble codes before I do anything else.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
4l60e Transmission out again...need help remington8189 Silverado 6 10-08-2014 04:16 PM
97 4L60E Trans problem mavbeacon Silverado 9 10-07-2012 12:28 PM
4l60e shift issues after rebuild onedbdred C/K 3 02-14-2010 01:26 AM
Silverado Corvette Servo 4L60E Silverado_Dude Silverado 0 08-14-2009 08:50 PM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
