Old 03-14-2011, 10:18 AM
Erik2002Winnie Erik2002Winnie is offline
2002 Taurus Radio Aux Input?
So I have the integrated radio with single cd, NO CASSETTE in my taurus.
I found this.
http://www.v8sho.com/SHO/Instruction...d%20Taurus.htm
Im trying to figure out how to add a aux in here.
I would be fine with stealing the functionality of the CD. Does the CD pinout to the rear the same way the cassette does?
Does anyone know the pins for that?
I am figuring I cant use the cassette outs as i have no way into tricking it to switch to that source.
OR
Is there a way I can tap into the changer plug in the back to hook up there? How would I fool it to see the changer. (I have no changer now)
Old 03-15-2011, 06:47 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 Taurus Radio Aux Input?
Does your stock head unit have a CD Changer button to select a changer if one were installed?
In addition to the left and right channel wires (shielded) there is also a System On signal (probably sourced from the RCU), cellular phone audio left and right (not sure the function of these), and "Audio Protocol" A and B lines. I'm guessing the audio protocol lines would need to see activity on them for the RCU to recognize a changer as present. I've never scoped these lines to see what function they play and no longer have a car that I could try that on anyway.
I think there was a thread on here quite some time ago regarding adding an iPod input to the stock system with an aftermarket interface module that's figured all this out before. I want to say it was a PAC Audio device. You might search this forum for details, try keyword "iPod".
-Rod
Old 05-25-2011, 11:04 PM
rdh2 rdh2 is offline
I found this.
OR
Same pins for CD out to RCU. Adding this audio jack works the same with the cassette or CD.
Old 07-09-2011, 09:14 PM
jaimysessanna jaimysessanna is offline
I have a 2007 SE. To be best of my knowledge, the RCU from 96 through 07 has the same style plugs/interface.
I have an XM Radio and I use a PIE audio device, works quite well. Others have had issues with them, I have not however. It taps into the un-used CD changer port on the RCU. It then has a left and right RCA input. I bough a 1/4" headphone to R+L RCA cable off of Newegg.com - 25' for about $15.
I got mine off of Amazon.com:
http://www.amazon.com/gp/product/B0015CY1WA
If you need any images, I can take some of my setup and put them up for you.
2007 Ford Taurus SE
3.0 Vulcan, AX4N, B&M Supercooler, PEAK Green Coolant, Mach RCU, Polk Audio db571
100,450 Miles
25 MPG all day long
Blazer -98 radio aux input Jari Interior | Exterior | Appearance 7 05-04-2007 07:37 PM
2002 Taurus Radio/Defroster Problems vandyrunnr Taurus | Taurus Wagon 9 11-24-2006 08:26 AM
99 Taurus SE Aux Input? Reggiewolf Taurus | Taurus Wagon 1 06-23-2005 01:38 AM
XM Radio - Aux input on OEM Radio? mcontrols Highlander/Highlander Hybrid/Kluger 0 03-06-2005 06:34 PM
Stock Radio Aux Input OSSA_MAR C/K 6 11-07-2003 12:30 PM
