Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-13-2011, 03:47 PM
fxrmike fxrmike is offline
96 cutlass more coolant problems
can fill radiator, open bleeders but no coolant. Can run with temp sender out will only let steam out. did this for at least 30 min. with sender in it will go over so far the needle touches the zero on speedo. I can get plenty of air but no coolant. It's a 3.1 with new thermostat, radiator cap, sender and water pump. Please help!!
Old 03-14-2011, 09:11 AM
aleekat aleekat is offline
Re: 96 cutlass more coolant problems
Where's the coolant going? On the ground?
Old 03-14-2011, 01:11 PM
No, it's not going on the ground and it doesn't seem to be going in the oil.
Old 03-15-2011, 02:44 AM
that leaves either out the exhaust, or from the radiator with pin hole leaks, ie..steam escaping.
Old 03-15-2011, 05:11 PM
brobison15317 brobison15317 is offline
It should be fairly easy to see if that much coolant is exiting. Is the emissions from the exhaust white and sweet smelling?
I have a 97 Oldsmobile, 97 Lumina, and 98 Lumina. All 3.1L engines. The fact is the head gasket needs to be replaced along with head bolts every 75K miles. I just finished my second head gasket repair about 10K miles ago. THe 2 Luminas have had a repair each.
If you haven't replaced the head gasket yet and you are close to 75K or over. I would think that you are seeing this
96 Cutlass Supreme brake problem Bunky1267 Cutlass Series 3 03-13-2011 03:56 PM
95 Cutlass Supreme coolant tank/bottle riclandero Cutlass Series 1 07-16-2008 07:32 AM
Yet again more coolant problems.... iamsodamnconfused Grand AM 0 02-01-2006 01:44 PM
1995 Cutlass V6 Coolant Leaking Into Oil cdlubbe Cutlass Series 2 05-22-2005 09:08 AM
Cutlass leaking coolant admjones Cutlass Series 5 01-24-2004 07:45 PM
