Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-13-2011, 12:47 PM
Bunky1267 Bunky1267 is offline
Question 96 Cutlass Supreme brake problem
I'm looking at a 1996 olds cutlass supreme 4 door in decent shape 200,000 plus miles, runs good, but the ABS and Brake light on and by the rust on the rear disc the rear brakes are not working. I don't see any fluid leaking but my suspicion is that there's a leak and the proportioning valve is switched over to block fluid to the rear...
Anyone have any suggestions ???
Old 03-13-2011, 01:02 PM
inafogg inafogg is offline
Re: 96 Cutlass Supreme brake problem
the only way is to start checking the system,see whats froozen/rusted
by inspection.
check the brake fluid,if low/empty fill check for leaks
hows the pedal feel
scan the ABS system see what codes are stored
the basic have to done 1st
Good luck
btw you can spend alot,so make sure car is worth it
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-13-2011, 01:34 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
From what I recall, these cars are notorious for seized rear calipers, especially in the Rust Belt.
Anticipate new calipers, pads and rotors on the back, along with whatever other repair is needed.
Old 03-13-2011, 02:56 PM
old_master's Avatar
Advisor/Moderator
Spot on perfect! The parking brake mechanism is built into the caliper. Absolutely the WORST design for rear disc brakes. The sad part of it is, even when you replace all of the parts, it'll do the same thing in a matter of months.
You have to know how it works,
to figure out why it doesn't.
94 Cutlass Supreme Idle problems benniewillett Cutlass Series 1 03-17-2010 01:39 PM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
Possible Exhaust Back pressure on 96 Olds Cutlass Supreme chrisluna Cutlass Series 4 10-16-2009 05:01 PM
96 Cutlass Supreme with Alternator trouble chrisluna Cutlass Series 4 10-05-2009 04:34 PM
96 Cutlass Supreme w/ humming noise coming from under the back of the car chrisluna Cutlass Series 1 09-28-2009 12:11 PM
