Go Back   Automotive Forums Car Chat > Mercury > Mariner/Mariner Hybrid
Old 03-12-2011, 07:42 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Oil filter
Hi there,
I just changed the oil on my mom's '09 Mariner 3.0L V6. I went to the local parts store looking for the FL-500S filter but they had none. Their computer said an FL-820S is an alternative filter. I had a box of these sitting at home for use in my 4.6L mod motors so I used one.
Upon looking at old FL-500S I took off and the FL-820S, the o-ring size and the thread seemed to be identical. It appeared that the only difference is the FL-820S is wider. It it close to the catalytic converter heat shield but there is some room between them for road movement.
Is it okay to leave the FL-820S filter on or should I go to the dealer to get an FL-500S as no one else seems to carry them? I started it up to ensure a tight seal of the o-ring and it seems to be okay.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 06-21-2011, 06:51 PM
rhandwor rhandwor is offline
Re: Oil filter
Originally Posted by Blue)(Fusion View Post
Hi there,
I think it will be fine on your mothers car. Look at the filter in a couple of weeks if the paint on the filter doesn't look badly discolored you should be fine.
2006 slk350 - oil & filter change question ninja650R SLK 6 07-17-2009 09:00 PM
Oil filter/ oil survey hodges04 Tiburon | Tuscani 2 04-05-2004 11:16 AM
Oil leaking from oil filter....PLEASE HELP how2lose101 General Discussions 3 02-23-2004 06:19 PM
Oil and filter change... best oil???? additive??? 92GrandprixSE Grand Prix 2 01-30-2004 07:20 AM
