Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-11-2011, 07:54 PM
TCHRISD TCHRISD is offline
LSS belt change [need help].....
I have a '96 LSS non-SC'ed. the belt broke so I went to replace it and appearently you have to remove that whole mounting bracket thing. Is there an easy way to do this and does someone have steps to do this either way?
thanks guys!
Old 03-12-2011, 11:20 AM
Blue Bowtie's Avatar
Registered Offender
Re: LSS belt change [need help].....
There isn't really an "easy" way to do this, but there is an easier and safe method. The right (front?) engine mount bolts should all be loosened. What I have done is remove them one at a time and lubricated them with anti-seize compound so that they can be spun in and out quickly by hand - The long ones through the frame rail mount can be difficult due to corrosion. Once the bolts are easy to spin in and out you can support the engine at the right end (front of the engine) with a soft wood block and jack. Remove the mount from the engine and slip the old belt out and the new belt in, remembering that only one side of the belt need to pass through the mount. Install the mount to the engine and tighten the bolts, then remove the jack holding the engine up. Finish installation of the belt around the sheaves and the tensioner.
Old 03-12-2011, 01:40 PM
Any idea of the size of the reverse torx socket needed for the lower mount stud?
Need help with this mechanical question cartwrna Ninety Eight 6 05-09-2010 12:09 AM
Timing belt change, need advice mlingk Trooper | SLX | Bighorn | Wizard 6 11-28-2006 01:46 PM
possible belt problem?needs help! twoods1389 Forester 0 11-03-2005 03:10 PM
89 galant timing belt swap need help! 96eclipsegirl Galant 2 12-15-2004 09:08 AM
Mirage gearbox oil change, need help!! da5e Mirage 0 10-10-2004 05:06 AM
