Go Back   Automotive Forums Car Chat > Buick > Century
Old 03-08-2011, 01:51 PM
JSchlenk91 JSchlenk91 is offline
Turn Signal Problem
I have a 97 Buick Century Custom and I have am having problems getting the passenger side front turn signal to work. I have replaced the bulb, checked the fuse, checked/replaced the socket and tested the voltage to everything. The rear does work however. I am honestly just running out of ideas and anything would be highly appreciated. Thanks
Old 03-08-2011, 04:02 PM
Scrapper Scrapper is offline
AF Premium User
Re: Turn Signal Problem
do you have it grounded good? i don't know if trying a new flasher just a thought and it also could be in the turn signal switch it'self? by chance do you have the VAT'S SYSTOM IN THAT?
Old 03-08-2011, 05:43 PM
I believe that it is grounded good and yes it does have the VATS system. I have thought about replacing the flasher. I recently just switched my left side with the right side and it works fine so atleast I know that its not the socket.
Old 03-08-2011, 07:16 PM
I just replaced the flasher and now the signal display in the dash flashes normally and so does the rear signal however the front still does not blink at all.
Old 03-08-2011, 11:52 PM
dondeere dondeere is offline
I had same problem with 97 Deville. I removed and cleaned ground cables on the battery and the signal light worked.
Old 03-13-2011, 06:50 PM
stripe stripe is offline
I had a 96 with similar problem.
There was a socket that hooked/unhooked from harness.
Something to check.
Cheers
Stripe
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 11:40 PM
2003 Impala turn signals [email protected] Impala | Impala SS 4 08-14-2010 10:23 AM
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 07:20 PM
turn signal right - sometimes KronVickan Crown Victoria 6 01-29-2010 03:14 PM
turn signal lights not working x3mtm Durango 4 01-11-2010 01:49 PM
Tags
bulb , light , lights , signal , turn
