Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-06-2011, 07:05 PM
94HeavyChevy 94HeavyChevy is offline
low coolant
my 95 caprice 4.3L is slightly low on coolant. I have some dex cool from a different vehicle, is it ok to mix the dex cool in with the coolant in the car. I am going to get the coolant system flushed in about a week or so.
Old 03-06-2011, 07:11 PM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Re: low coolant
You should never mix coolants. Unless your car was meant to work with Dex Cool, don't do it. I have an '02 truck and can only use Dex Cool.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 03-07-2011, 09:17 AM
j cAT j cAT is offline
Re: low coolant
you may save 12.00 today by doing this coolant swap. once your system has been contaiminated the damage is an expensive one to correct. much more than 12.oo....
long term the engine will overheat and the gaskets start to blow out.
make sure the heater core is flushed out separately when the coolant is replaced. this should be done every 3-4 yrs when , this dexcool requires replacement.. always use DISTILLED WATER , tap water is dirty and contaiminated with corrosive chemicals.
your coolant is low , now is the time to find out why . not after the coolant replacement.
if the caprice has silicate coolant or compatible coolant you must stick with this coolant ..do not use dexcool if this is so.
also compatible coolants are not DEXCOOL. USE OF COOLANTS THAT DO "NOT" HAVE , THE GM APPROVED DEXCOOL ON THEM , ARE NOT TO BE USED WITH A VEHICLE REQUIRING DEXCOOL.
2000 Ford Taurus w/ Low Coolant Light ON dumb2cars Taurus | Taurus Wagon 3 02-21-2010 08:39 PM
High Coolant Temp and Low Coolant Warning Lights flashing scott3689 SC/SL/SW 2 10-25-2007 08:28 AM
Low coolant light on, but the coolant isnt low? NickF829 Malibu 1 10-01-2006 08:19 AM
Low Coolant/Low Traction/No Traction/Anti-Lock lights on Jim Rockford Alero 7 01-28-2005 05:39 PM
HELP ME!! Low Coolant light comes on, but plenty of coolant! lizabethbaker Camaro Discussions 3 12-01-2003 10:34 PM
